Author Topic: Stan's - Amati Grand Banks build  (Read 137837 times)
Stan
Re: Stan's - Amati Grand Banks build
« Reply #150 on: May 04, 2020, 06:42:33 pm »
Thank you all for your comments. Today I have been flitting about like a butterfly working on the windshield frame work and the cabin interiors  sanding sealing the cabin sides ready for the white primer. Also spent some time on the web looking more 1/24 scale items for this model more to follow later this week.
Stan. :-)) :-)) :-)) :-)) :-)) :-))
Stan
« Reply #151 on: May 06, 2020, 09:42:28 pm »
HI Guys all building stopped at the moment. Both my garden sheds need some T L C BUT i WILL BE BACK.
Stan.
Stan
« Reply #152 on: May 10, 2020, 04:03:27 pm »
HI Guys the lack of enthusiasm seems have gone for the moment  A good time was had on Friday and Saturday. Today it is very cold  not been far.
Stan. :(( :(( :(( :(( :(( :(( :((
DJW
« Reply #153 on: May 11, 2020, 10:22:46 am »
Morning Stan
Still trying to get the picture of you '...flitting about like a butterfly...' out of my head...   {:-{
Anyway, hope you've got the heater running in the shed, maybe had a tidy and found your enthusiasm.  :-))
Looking forward to next installment of the build.
Best regards
David.
Stan
« Reply #154 on: May 14, 2020, 09:45:27 pm »
HI Guys just a selection of items I have been working on. I hope to fit the inner cabin side with very small screws and the outer cabin side with  magnets this will give full access to to the internals of the cabin.
Stan.
« Reply #155 on: May 14, 2020, 09:51:46 pm »
Loads of fiddly bits being worked on there Stan.  O0
Like the way you've tackled those louvred vents - always tricky to get those things right but you seem to have found a way.  :-))
Stan
« Reply #156 on: May 15, 2020, 09:24:47 pm »
Today I have been making the side screen supports no pictures yet. Also built some brass work to go on the bow finally holes drilled in the main control panel. I hope next week to paint the fly bridge then start detailing
Stan.
Stan
« Reply #157 on: May 19, 2020, 08:02:03 pm »
Well the prep work on the fly bridge is almost finished hope to paint before Friday. I have enclosed some pictures showing the windshield supports and the card templates fitted .The hand rails are now finished with Humbrol metalcote polished aluminium next step varnish these. Other pictures show furniture and aerials just a few little jobs to finish hopefully tomorrow.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
john44
« Reply #158 on: May 19, 2020, 09:04:46 pm »
Looks like you've got the interest back, looking brilliant.
Stan
« Reply #159 on: May 20, 2020, 09:26:54 pm »
HI  the fly bridge is now coated in white primer. Gloss varnished the hand rails today first coat sadly i dropped one of them resulting it been covered in dust. Just another day at the office.
Stan. :(( :(( :(( :(( :(( :(( may be tomorrow. :-)) :-)) :-)) :-)) :-)) :-)) :-))
Stan
« Reply #160 on: May 21, 2020, 09:43:16 pm »
Fly bridge now painted.When its dry all the windshield supports need to be masked off and sprayed with metalcote.
Stan
« Reply #161 on: May 22, 2020, 09:49:29 pm »
The fly bridge is finally painted had a few problems yesterday. Now waiting for the paint to dry I will then mask of the windshield supports and spray with a metal finish. Last picture shows the fly bridge wheel mounting was going to be a problem simple answer a M2 brass bolt  just solder over the slot nice dome finish.
Stan
« Reply #162 on: May 25, 2020, 09:41:42 pm »
HI Guys today's updates I have been masking of the windshield supports ready for spraying with a metal finish paint. The flybridge hand rails have taken back to bare metal not happy with the finish. Tomorrow I will be spaying a test piece with a new chrome paint pictures to follow. I enclosed some pictures showing the masking required to paint the supports.
Stan
« Reply #163 on: May 27, 2020, 08:42:39 pm »
HI Further update  from the shed. Yesterday i sprayed the windshield supports polished aluminium not a good idea it looked awful. This morning they received a coat of matt white now happy with the finish. Also today magnets fitted under the seats  this will allow them to be removed to allow the fly bridge to be removed. I have started to make a sun lounger from plastic strip  and the table  both for the fly bridge.
Stan
« Reply #164 on: May 27, 2020, 09:23:32 pm »
Just found a great picture of a lounger the plastic one may be for the bin.
Stan
« Reply #165 on: June 02, 2020, 04:34:51 pm »
HI the fly bridge area is now painted just some small trim to fix then its time to apply the varnish finish. This will be made of 2 parts gloss varnish and one part satin all Humbrol clear cote. Just a few pictures showing the fly bridge with the seating fitted also the instrument panels and the L E D  fitted to one of them. Whip aerial also and some small items in a box ready for fitting
Stan
« Reply #166 on: June 02, 2020, 09:33:58 pm »
Just one picture tonight showing the fly bridge panel illuminated with a Yellow/ White 2 mm L E D.
« Reply #167 on: June 02, 2020, 10:06:41 pm »
Wow, that's a great looking instrument panel - good work Stan.  :-))
DJW
« Reply #168 on: June 02, 2020, 10:20:30 pm »
Agreed. Nice work Stan.  :-))
john44
« Reply #169 on: June 03, 2020, 07:49:56 am »
Hi Stan, great work as usual. It's a good even light across the panel amazing for just 1 2 mm led.
I have often thought of getting a led tester but never got around to it.
Stan
« Reply #170 on: June 04, 2020, 09:51:56 am »
HI today's post I have changed the L E D in the interior control panel. I have used a yellow /white 2mm L E D far better than the orange one. I hope to fit the last pieces of wood trim then its varnish time pictures to follow.
Stan
« Reply #171 on: June 04, 2020, 06:36:21 pm »
Hi Just a few pictures showing resistors  fitted in various parts of the furniture and one showing the 2mm L E D I use on all my models.
CJK
  • Growing old is mandatory - growing up is optional
« Reply #172 on: June 04, 2020, 07:35:27 pm »
Impressive detail on your models Stan  :-))
« Reply #173 on: June 04, 2020, 10:21:13 pm »
Crikey Stan, that is wonderful work! You remind me of a chap at my local club who builds super detailed models like this with gadgets and details. He fitted a working telly (LCD screen and mini MP3 player or similar) and a radar screen with mini LCD)
Keep that top quality work up mate  :-))
Re metallic finishes. You have probably heard of Alclad already, but their system is first rate with microscopic pigment size and super shiny chrome. They do a whole range of metal finishes. http://alclad2.com/
Stan
« Reply #174 on: June 10, 2020, 08:41:38 pm »
HI all sorry no further updates at the moment I need a short break.I will be back.
Stan. At the moment :(( :(( :(( :(( :(( :(( :(( :((  hopefully by the week end. :-)) :-)) :-)) :-)) :-)) :-))
Page created in 0.029 seconds with 21 queries.
