Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... 23   Go Down
Author Topic: Stan's - Amati Grand Banks build  (Read 102335 times)
Stan
« on: August 05, 2019, 10:04:07 pm »
Hopefully this will be the start of my build thread for the above model. Major construction will not start before we enter the winter period. It is very obvious that new materials will have to be used to reduce top weight this will mean many of the parts in the kit will not be used. The first pictures show the build board that will be used to construct the main section of the superstructure. More information will follow when the build starts.
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
Re: Stan's - Amati Grand Banks build
« Reply #1 on: August 05, 2019, 10:34:02 pm »
That's a good solid board you've put together Stan and with plenty of space to get your hands underneath  :-))
Stan
« Reply #2 on: August 05, 2019, 11:06:50 pm »
Hi Ray I will be fitting some studs this will allow me to clamp down the base of the superstructure during construction.
Stan
Stan
« Reply #3 on: August 14, 2019, 03:17:01 pm »
Just placed a order with prop shop for the running gear now looking for companies the stock thin veneers.
Popeye
  • I see no ships!
« Reply #4 on: August 14, 2019, 05:30:18 pm »
Hi Stan.
What prop size have  you chosen and what motors do you intend to use?
Popeye
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
Stan
« Reply #5 on: August 14, 2019, 09:28:54 pm »
Hi 30mm 3 bladed may go up to 35mm if needed. Motors are small brushless power will be from lipo batteries.
Stan.
barriew
« Reply #6 on: August 15, 2019, 06:33:07 am »
Have you seen this company? Not used them, just logged in case of need.
https://woodveneeruk.co.uk/
Barrie
Stan
« Reply #7 on: August 15, 2019, 10:15:42 am »
Thanks .
Stan.
Stan
« Reply #8 on: October 22, 2019, 05:48:30 pm »
Motors and prop shafts and rudder assemblies now purchased. Today I have marked out the locations of the above items. Foam board laminated to make the rudders pictures to follow.
Stan
« Reply #9 on: October 25, 2019, 03:37:52 pm »
I hope to have the rudders in place by next week pictures will follow.
Stan
« Reply #10 on: November 02, 2019, 04:43:18 pm »
HI  rudder posts now in place  and 8mm holes drilled in the deck to help lighten the hull weight. Next group of picture will show all running gear fitted.
Mark T
« Reply #11 on: November 02, 2019, 05:09:18 pm »
Yay - I've been waiting for this to get going Stan.  I'm following  :-)
Mark T
« Reply #12 on: November 02, 2019, 05:10:34 pm »
Mind you I think you need to put your glasses on mate as it would seem that you drilled a few holes for the rudder before you found the right place  {-)
Stan
« Reply #13 on: November 02, 2019, 08:36:03 pm »
I would need big rudder posts. {-) {-) {-) {-) {-)
timg
« Reply #14 on: November 02, 2019, 09:09:55 pm »
Hi Stan
You're off to a good start ,and very neat  (as always ), are the hull and deck made from GRP  ?
I will also be watching
timg
Mark T
« Reply #15 on: November 02, 2019, 09:20:58 pm »
Or fit 40 rudders Stan - mind you it would turn on a sixpence  {-)   Looking forward to the next update  :-))
Stan
« Reply #16 on: November 02, 2019, 09:27:44 pm »
Hi timg the hull is g r p the deck areas are g r p moulded into the hull. Fitted over the drilled areas are the timber deck sections.
Stan.
Stan
« Reply #17 on: November 05, 2019, 03:09:57 pm »
First prop shaft fitted  masking tape is to stop glue dropping out .
Stan
« Reply #18 on: November 07, 2019, 09:46:24 pm »
Shafts and motors are now fitted. The rudder posts are a problem at the moment pictures to follow.
Stan. :-)) :-)) :-)) :-)) :-))shafts. {:-{ {:-{ {:-{ {:-{ {:-{Rudders
Stan
« Reply #19 on: November 08, 2019, 09:22:28 pm »
Pleased to say shafts and motors  are now installed hope to have the rudders in place this weekend.
Stan.
« Reply #20 on: November 08, 2019, 09:26:38 pm »
Any progress is better than none Stan - another neat installation job coming up  O0
Stan
« Reply #21 on: November 09, 2019, 08:46:02 pm »
Rudder posts now in place and rudders fitted. Servo mount under construction hopefully some pictures later this week.
Stan.
Stan
« Reply #22 on: November 12, 2019, 06:08:42 pm »
The rudder posts and servo now fitted and tested also the fuses fitted these will be on the supply from  the battery.
Stan
« Reply #23 on: November 13, 2019, 10:34:41 am »
This morning I have made the tray from plastic card for the R/X  gear pictures to follow.
Stan
« Reply #24 on: November 13, 2019, 02:14:50 pm »
Just a few pictures showing cables fitted to the fuse holders  and the plastic tray made to fit the R/X equipment.
Technical info
20 amp b/less motors.
30 amp E S C. 15 amp controllers would not meet  the motor needs
18 Amp cable.
Two 15 amp fuses protect all the above.
Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... 23   Go Up
Page created in 0.09 seconds with 22 queries.
