Author Topic: Water Jets  (Read 4404 times)
redpmg
Water Jets
« on: August 08, 2019, 09:56:23 pm »
Anyone lucky enough to have a 3d printer - here's a give away of a water jet - looks good
https://cults3d.com/en/3d-model/various/water-jet-propulsion-system-janikabalin
RST
Re: Water Jets
« Reply #1 on: August 08, 2019, 10:14:13 pm »
I'd print it right now but it wants a subscription, so no thanks this time.  Looks good though, nice smooth plenum compared to allot out there.
redpmg
Re: Water Jets
« Reply #2 on: August 08, 2019, 10:19:23 pm »
That's odd - already downloaded by a couple of others ......
JimG
Re: Water Jets
« Reply #3 on: August 09, 2019, 02:06:05 pm »
Just checked it out, asking for a subscription here as well. Looking at your design there is one thing of concern, you have the impeller at the end of a relatively long unsupported shaft with just one bearing. Unless the impeller is perfectly balanced will this not allow it rub on the casing? The Graupner jets in their pilot boat have a second bearing behind the impeller.
Jim
Dundee Model Boat club
johnv
Re: Water Jets
« Reply #4 on: August 09, 2019, 06:14:50 pm »
Hi it's John V I have been testing Jet drives for model boats I agree on that one it needs a second bearing .but hue am I to say cheers John V
redpmg
Re: Water Jets
« Reply #5 on: August 09, 2019, 07:16:50 pm »
Not my design - simply came across the link- and thought it might be of interest to some- criticise the designer if you like  - however if you have a 3d printer and the software for it should be easy enough to convert to two bearings.
 I often do that with Corel on old plans that are mostly iffy - noticed  the jet does not have a weed grid either.
kinmel
Re: Water Jets
« Reply #6 on: August 12, 2019, 11:26:44 pm »
If anyone wants the files for this water jet, PM me.
martno1fan
Re: Water Jets
« Reply #7 on: September 12, 2019, 10:37:18 pm »
Go to rcgroups jetboat forum theres a free set of plans available for a jet pump and a lot of good info too plus they are upgrading and changing things to improve the design all the time.I have a very large 45 mm version someone else printed for me for free .
https://www.rcgroups.com/jet-drive-boats-1004/
Page created in 0.015 seconds with 21 queries.
