After quite a few years away from model boats I'm about to start building the MS Tamar kit.
I've searched through a lot of posts and general consensus seems to be that a pair of Overlander 3548/05 900Kv motors and Fusion Hawk BL 60A ESCs is the combination of choice for the 1/16 Tamar. Or would be is the Fusion Hawk hadn't become discontinued/unavailable. I've spent several days trying to figure out an alternative combination but with my limited knowledge of brushless motors I'm becoming increasingly less certain of the best way forward and some help would be really appreciated.
The first option would be to simply replace the Fusion Hawk's with a suitable equivalent but with the motor's 60A requirement the ESC choices seem limited. Most seem to be the more expensive water cooled variants. A lot of the rest seem to lack the necessary forward/reverse option.
The alternative option may be to replace the 3548's with say the Overlander 3536/08 1050 Kv. With the lower current rating (30A) that would potentially give a greater choice of ESC (for example, the Mtroniks tio Marine 30). But I'm unclear on what the impact would be on the performance. I'm looking for realistic scale speed but still to get the bow planing.
Is there a third option?
Originally I had planned on running these with a pair of 9.6v NiMh battery packs and a pair of 40mm 4 blade props (again, general consensus suggests that's a good choice).
Thanks in advance for any help
Steve
