Author Topic: Power options?  (Read 3452 times)
mikelimajuliet
Power options?
« on: August 22, 2019, 02:53:56 am »
Hello everyone living in my computer.
This is my first post here but I have built a few plank over frame yachts in the past the latest being a Racing Sparrow RG65.
I have for a number of years hoped to make a model of the MS Angelina Lauro as she appear in 1969 when my mum brought over to New Zealand on her.
I have source plans and will soon start construction on the hull which will be just over 2m long.
My question today, however, is this...
What I would like recommendations from the most august membership is how I should power her. I don't think space will be an issue.
All suggestions of a proper nature welcome. %%
Cheers Mike
Martin [Admin]
Re: Power options?
« Reply #1 on: August 22, 2019, 11:51:44 am »
Hello everyone living in my computer...
Haha, love it!
What I would like recommendations from the most august membership ....
That would be me then ! %)
Liners / Ferries don't need much power, many I've seen have 380 / speed400 size motors and 6v / 7.2v / 7.3v batteries.
.... Lets get carlmt to chip in here, he Mr Ferry....!  :-)
carlmt
    • Linkspan Models
Re: Power options?
« Reply #2 on: August 22, 2019, 12:01:54 pm »
From my quick research, this ship was triple screwed.
With a hull of 2m long, I would most likely opt for 3 x Mabucci 555 motors : smooth running.  I would suggest 40mm props would be plenty.
This is the set-up we have for our Norland ferry kit and she is 1.8m long approximately.
Hope this helps?
Carl
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: Power options?
« Reply #3 on: August 22, 2019, 01:44:22 pm »
Hope this helps?
Carl
Nice looking ship!    I like simple, proven and reliable.  If it were me, I'd be going with the above 3x 555 motors suggestion - I'd be using a lead battery for free ballast too.
canabus
Re: Power options?
« Reply #4 on: August 22, 2019, 01:50:04 pm »
Hi Mike
540 rock crawler brush motor 45 turn(35mm) on 7.2 volts(2S lipo) will give 9500 rpm unloaded and would easily turn 40mm props.
Raboesch prop chart( a free PDF download) shows 40mm prop max rpm 8800.
Canabus
DaveM
  • Why on earth do I do this?
Re: Power options?
« Reply #5 on: August 22, 2019, 01:52:06 pm »
Are these the Italian clones of the original ones, Carl?  ok2
Good to see you're back on here and I hope your back troubles are subsiding.
DaveM
RST
Re: Power options?
« Reply #6 on: August 22, 2019, 07:36:42 pm »
I bought 2 mabuchi 555 motors a couple of years back thinking they were right for my application.  Did a bit of searching, they don't seem to have good write-ups on forms at all.  OK for power drills, not models!  I don't know whether I have good or bad ones.  Too timid to try them now. LoL.
carlmt
    • Linkspan Models
Re: Power options?
« Reply #7 on: August 22, 2019, 09:02:18 pm »
Not had any problems with those in my Norland.
Got a couple in our new Spirit of Free Enterprise too!
carlmt
    • Linkspan Models
Re: Power options?
« Reply #8 on: August 22, 2019, 09:05:18 pm »
DaveM
Ha ha  {-) {-)  Yep! Spelling is not my forte......... Mabuchi.........
https://www.componentshop.co.uk/mabuchi-555-dc-motor-mounting-bracket.html
And yes, thanks Dave!  Back is slowly getting better.... I can walk without my third leg now - but Christ it has been painful  <:( <:( <:(
mikelimajuliet
Re: Power options?
« Reply #9 on: August 23, 2019, 02:27:21 am »
Thanks guys, Lots of good information here. I will look into the Mabuchi motors
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: Power options?
« Reply #10 on: August 23, 2019, 08:51:45 am »
It's a lovely looking ship - great lines - and not an unmanageable size - I wonder if it would be worth taking a mould of your finished hull to be able to duplicate it in fibreglass?
mikelimajuliet
Re: Power options?
« Reply #11 on: August 29, 2019, 02:21:00 am »
Having now spent many hours staring at the plans I notice that she would swing three 50mm props.
Would this change the motor requirements and would the motors need to be controlled by separate ESCs
Another though has occurred while I write this, do the screws turn in opposite directions?
 and now a further thought from one of the other voices in my head wants to know if Penguins have knees (nothing to do with the topic I know but just a thought)
JimG
Re: Power options?
« Reply #12 on: August 29, 2019, 11:48:35 am »
If you are using brushed motors then you can use a single esc to control them, however you will need to make sure that it can cope with the total current from 3 motors. May be best to have one esc per motor. If you go to brushless then you must have one esc per motor.You will find that the two outer props will generally turn in opposite directions. ( If you search on the forum you will find lots of discussion on whwther they should be outward or inward turning.)As for penguins I believe that one of our forum members is an expert on the topic.
Jim
Dundee Model Boat club
mikelimajuliet
Re: Power options?
« Reply #13 on: September 16, 2019, 02:34:21 am »
Thanks Jim, I was looking online at the Action units and was wondering if the P40 controller would serve the purpose as it can control 3 motors and has the addition of slowing the motor on the inside of the turn?
DaveM
Re: Power options?
« Reply #14 on: September 16, 2019, 08:28:59 am »
The P40 controls the speed controllers, not the motors. It will work with either brushed or brushless speed controllers (one for each motor). If you want a unit which will act as both speed controllers for two motors  and a rudder/motor mixer- with the option of including a third ESC for the centre motor - then have a look at the P94.
DaveM
mikelimajuliet
Re: Power options?
« Reply #15 on: September 17, 2019, 01:47:58 am »
Thanks Dave, what ESC would you recommend for the third motor?
DaveM
Re: Power options?
« Reply #16 on: September 17, 2019, 08:09:07 am »
If you're using the P94 and three 555 motors then a P79 speed controller would do the job. If you go that way then make sure the acceleration slope of P79 is set to Linear and not Soft-Start.
DaveM
mikelimajuliet
Re: Power options?
« Reply #17 on: September 17, 2019, 09:00:29 pm »
  Thanks Dave you are a fountain of knowledge! No doubt I will have a tonne more questions before this build is over
Page created in 0.101 seconds with 21 queries.
