Author Topic: lg bluetooth headphones  (Read 1443 times)
regiment
« on: September 06, 2019, 07:25:57 pm »
is it possible to use 2 sets of blue tooth head phones on tv 43 um 4k 7400plb
mrlownotes
Re: lg bluetooth headphones
« Reply #1 on: September 06, 2019, 07:54:55 pm »
Hmmm, I bet your not the first to want to be able to do that -
A quick search on 'tinternet' revealed this link :-
https://intotomorrow.com/listening-to-the-same-audio-on-several-bluetooth-devices-at-once/
Hope it helps in some small way.
Bintur Ellenbach
regiment
« Reply #2 on: September 08, 2019, 02:23:10 pm »
email from lg only one set of blue tooth  head phones  can be used  on new tv a step backward
mrlownotes
« Reply #3 on: September 08, 2019, 05:21:32 pm »
Take a look at at ebay item number
254338377433
The title of the adapter is -
Bluetooth Transmitter Audio Receiver Multi-point Music Adapter Splitter Device HIt lets 3 bluetooth headphone sets be used concurrently.
You may have to use the 'audio out' from the TV and let the splitter do the 'bluetoothing'.
I haven't use one myself, but just had to do a bit of research to see what was out there !
Good luck.
Bintur Ellenbach
« Reply #4 on: September 09, 2019, 09:04:09 am »
The concept that created Bluetooth is that it would be short range and private.  There only being one live connection follows from this.  A 3 way splitter as shown above is effectively 3 bluetooth nodes in a box that plugs into the TV audio out hole that each set of phones can communicate with, one node per set of phones.
The advantage is fewer wires to angle and trip over.
To use multiple headphones from one socket, you need an adaptor.  Quite likely the power to each set of headphones will be noticeably cut as more are plugged in before they tie themselves into a knot.
Page created in 0.097 seconds with 21 queries.
