Author Topic: Alternatives to Chrome Plating (Electroplating)  (Read 2541 times)
SJG001
« on: September 29, 2019, 07:41:53 pm »
I am scratching my head at the moment trying to think of an alternative to electroplating on a restoration project - any suggestions would be appreciated
mrlownotes
Re: Alternatives to Chrome Plating (Electroplating)
« Reply #1 on: September 29, 2019, 08:35:49 pm »
Silver paint ?
https://www.ebay.co.uk/itm/323898279692
I've never used it, but it has been recommended for a silver finish.
Bintur Ellenbach
big_bri
« Reply #2 on: September 29, 2019, 09:21:24 pm »
I use Molotow liquid chrome, you need to seal it with Alclad II klear kote as other clear cotes turn it grey.
Works for me every time.
A couple of brass fittings finished with it
Brian
big_bri
« Reply #3 on: September 29, 2019, 09:23:21 pm »
All the fittings on my motorboat were finished with it and have so far stood up well.
Brian
ChrisF
  • What's my favourite cake!
« Reply #4 on: September 30, 2019, 11:38:27 am »
Looks just the job. Do you spray the Klear Kote on?
Chris
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All scratch built and to a scale of 1:12
big_bri
« Reply #5 on: September 30, 2019, 12:25:18 pm »
I did with mine Chris, I layed on three coats and it looks pretty cool  :-))
Brian
grendel
« Reply #6 on: September 30, 2019, 12:57:13 pm »
another vote for that brand of liquid chrome, used it directly on a 3d printed plastic part, to great effect.
Tug Fanatic
« Reply #7 on: September 30, 2019, 02:31:03 pm »
Works for me every time..................
Looks really good. I notice that they do various nib sizes - 1mm 2mm 3mm 4mm 5mm & possibly more.
Any thoughts on what size(es)
Taranis
  • Balne Moor MBC
« Reply #8 on: September 30, 2019, 03:02:44 pm »
Depends on the size of the object you want to detail
ANDY
grendel
« Reply #9 on: September 30, 2019, 04:41:17 pm »
I have a thin one and a thick one (2mm and 4mm from memory)
Tug Fanatic
« Reply #10 on: September 30, 2019, 06:34:29 pm »
I realise that but as I have no idea what the nib size really means I was interested in which sizes someone who has used them found useful.
Taranis
  • Balne Moor MBC
« Reply #11 on: September 30, 2019, 06:36:30 pm »
Nib size is exactly as advertised
So if you want to detail recessed bolt or screw heads you would need the smallest
Be wary of pricing as it varies dramatically from seller to seller
This is one of the better sellers https://www.ebay.co.uk/itm/Molotow-Marker-703-Liquid-Chrome-1mm-/252776135671?hash=item3adaa1bbf7
and one of the cheekiest
https://www.ebay.co.uk/itm/Molotow-MO703112-Liquid-Chrome-Set-of-2-1-x-1-mm-and-1-x-2-mm-Marker-Pen-/303287842801?hash=item469d5d37f1
ANDY
« Reply #12 on: September 30, 2019, 07:08:43 pm »
Keep us all updated on how you get on please SJG.
I know for sure I'm going to need something like this too, later in my current build  :-) .
grendel
« Reply #13 on: September 30, 2019, 07:16:49 pm »
here are the 4mm and 2mm nibs, they are quite broad even for the narrow one
ChrisF
« Reply #14 on: September 30, 2019, 07:41:05 pm »
Thanks Brian. I'm a little way off needing it on my builds but it's going in my notebook!
Chris
Popeye
  • I see no ships!
« Reply #15 on: September 30, 2019, 07:59:13 pm »
This product sounds too good to be true, though, having viewed preceding photos, seeing is believing.
(1) Can it be applied successfully to brass and/or copper rod and tube?
(2) Any experience of how long before the chrome finish deteriorates when exposed to fresh water?
Thanks.
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
big_bri
« Reply #16 on: September 30, 2019, 09:18:27 pm »
I've no experience with tubing, but have used it on brass fittings with great success. As for durability, as its sealed with a clear cote, I personally have no need to doubt it will last.
Brian
Taranis
  • Balne Moor MBC
« Reply #17 on: September 30, 2019, 11:00:16 pm »
I must say thank you Brain  :-)  I did not know about the clear coat and a nice thing learn  :kiss:
ANDY
SJG001
« Reply #18 on: October 03, 2019, 10:16:16 pm »
many thanks for your responses - unfortunately due to the area involved  I will have to fall back to electroplating.
So looks like I will be learning brush electroplating
« Reply #19 on: October 03, 2019, 11:17:20 pm »
This may be of interest, although the process uses Nickle [Ni] as the deposit material
https://www.sifcoasc.com/what-is-brush-plating
The vast majority of bright metal [and plastic] components we see today are Nickle plated and not Chromium plated .....[quite some reading required]
Remember the Moh hardness Scale from high school....Diamond = 10.0 Moh Scale, Talc = 1.0 Moh Scale
The down side of brush plating Nickle is that the material itself [Ni] = 4.0 on the Moh Scale, whereas Chromium [Cr] is 8.5
Yes... <*< more reading............. Derek
SJG001
« Reply #20 on: October 04, 2019, 03:28:43 am »
Thanks - the engine has parts on the frame which were originally chrome plated and that may be the reason for the high level of corrosion on some of the parts. I am going to have to  and dry it out prior to disassembly - I am guessing it was stored in a very wet environment.
Not sure the seller knew what he was selling - its a different model from the one advertised and earlier. unfortunately this makes disassembly a nightmare. Bonus though - may now have an excuse to buy a sand blasting cabinet.
Page created in 0.106 seconds with 22 queries.
