Pages: 1 [2] 3 4   Go Down
Author Topic: Artesania Latina Cutty Sark  (Read 15485 times)
kpnuts
Re: Artesania Latina Cutty Sark
« Reply #25 on: November 18, 2019, 08:49:44 pm »
Hi all couldn't resist a bit of varnish (just to see the beauty of the wood grain)
kpnuts
« Reply #26 on: November 21, 2019, 09:22:48 pm »
Planking nearly done now
Hope things carry on the way they are.
kpnuts
« Reply #27 on: November 27, 2019, 08:49:38 pm »
Hi all, sooo close
Shaping the planks to fit the ever narrowing spaces  (scharf joints I think their called ) is a very slow job (and each one is a different shape) but it is surprisingly satisfying when they finally fit.
« Reply #28 on: November 27, 2019, 09:03:30 pm »
Coming along nicely kp.
The odd shapes you mentioned are known as 'stealers'  :-)) .
kpnuts
« Reply #29 on: November 29, 2019, 09:00:29 pm »
Finally finished the planking of the hull, luckily the top half is black so I can hide the bad bits under the paint, I'm really pleased with the bottom half though which is good since I will just be varnishing that and leaving the wood to show.
I must admit its turned out far better than I hoped it would.
SailorGreg
« Reply #30 on: November 29, 2019, 10:28:51 pm »
kpnuts
« Reply #31 on: December 01, 2019, 08:31:58 pm »
Hi all planking done and varnished, made up the stand, painted the black top part and added some more to the decking structure.
kpnuts
« Reply #32 on: December 04, 2019, 08:54:59 pm »
Bit more done on this.
kpnuts
« Reply #33 on: December 09, 2019, 09:05:24 pm »
Hi all well I'm on to the gunwale covers (why they are called that I dont know, they cover nothing have nothing to do with guns and what wale's are I've no idea) anyway I've made a jig to get all the holes in the same place.
Drilled all 52 holes
Gunwales installed
Bit annoyed with the instructions (and myself for not checking) they tell you to drill 52 holes @ 1.5 mm but the brass wire they supply is only 1 mm
JimG
« Reply #34 on: December 10, 2019, 12:01:51 pm »
The gunwale (or gunnel) was a region of thickened planking round the gunports in a sailing warship. This was to provide more strength to the hull. This evolved over time to the top section of hull planking often including the internal planking at deck level. So your gunwhale covers will cover the top of the planking inside the bulwarks to cover the gaps between frames.Wales were sections of thickened planking to give localised strength to the hull, chainwales (channels) were where the lower ends of the standing rigging attached to the hull.
Jim
Dundee Model Boat club
SailorGreg
« Reply #35 on: December 10, 2019, 06:00:39 pm »
Splendid job kp.  This is going to look gorgeous when finished.  :-)) :-))   Hope you have a nice space allocated for display.
(One small query - why the small protusion below the forefoot - is there another piece to be added to the keel?)
Greg
kpnuts
« Reply #36 on: December 10, 2019, 09:05:40 pm »
No sorry mate just not removed it yet.
Well shes got a name on her now, I feel shes looking like a ship now and with the lines on the side the proportions are looking better (I did think without them she was looking slab sided)
kpnuts
« Reply #37 on: December 15, 2019, 05:40:19 pm »
Hi all finished the planking on the bow (those little bends in the 2x2mm sapeally were a real pain in the bum, that is the 12th set of those, they kept snapping when trying to bend them) I finally managed to get the bend by soaking them in boiling water then giving them 2 mins in the microwave.
kpnuts
« Reply #38 on: December 22, 2019, 05:04:41 pm »
Got some more work on this one done.
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #39 on: December 22, 2019, 05:10:18 pm »
I'm amazed at your skill and patience with this model / wreck rebuild!  :-))
kpnuts
« Reply #40 on: December 28, 2019, 09:04:57 pm »
Thanks mate.
Hi all did some to the stern cabin on this, I must say I'm really enjoying this.
kpnuts
« Reply #41 on: January 06, 2020, 08:02:34 pm »
I made a simple jig to keep the ribs the same distance apart and to keep them perpendicular to each other
Made the cats whiskers too.
kpnuts
« Reply #42 on: January 08, 2020, 08:57:16 pm »
I know I'm jumping ahead a bit (well quite a lot) but I thought it might be interesting to add some of the deck furniture.
I made another little jig for the covers for the hatch as there are a lot of them and they all need to be the same.
kpnuts
« Reply #43 on: March 04, 2020, 09:12:53 pm »
Ok so I'm back on this, first thing to sort is something that's been bugging me since I noticed it in the photos (didn't notice it on the actual thing for some reason) the cowls the anchor chains go into (sorry dont know what they're called) are not the same distances from the hold frame.
So sorted that (disguising the old hole was a pain but I dont think it notices now)
Personally I think this is a great kit (I know some people say otherwise) I dont know anything about the other kit as I've not built them but I'm not too worried about accuracy so i not too bothered about whether it's the right hull lines or too wide, whatever.
They give you ample material to build her (up till now since my brother stripped the planking off and I stripped all the decking off) they give you nearly enough to build her twice, i only had to buy 10 strips of decking to finish that off and have not had to buy any of the side planking and still have loads left over the quality of the materials is top notch my only slight complaint is the instructions are quite confusing (that said they give you a full size high quality photo of the finished model so you can measure and check off that)
kpnuts
« Reply #44 on: March 11, 2020, 09:00:24 pm »
More work on her, the forward cabins were very confusing.
The steps were a pain to fit and to be honest they couldn't be used anyway, look where they are you would have to get round the belaying pins and anyway they come out under the poop deck (incidentally that is exactly where the instructions tell you to put them.
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #45 on: March 12, 2020, 09:24:00 am »
I'm continually amazed at the quality of work you are producing considering the broken wreck that you started with!   :-))
kpnuts
« Reply #46 on: March 12, 2020, 05:52:51 pm »
Thank you so much, I'm glad you like it.
kpnuts
« Reply #47 on: March 12, 2020, 09:01:46 pm »
Hi well I've got the latrines and the latrines pump done, this is such a major undertaking I can see at least another 2 yrs in this kit.
kpnuts
« Reply #48 on: March 15, 2020, 05:58:05 pm »
Done some of the panels round the top rails and made a start on the bowsprit, even added the figurehead.
Tafelspitz
  • Model Boat Bedlam
« Reply #49 on: March 16, 2020, 08:46:40 am »
Simply amazing work! Just like the real thing. Awesome! :-))
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
Pages: 1 [2] 3 4   Go Up
Page created in 0.136 seconds with 22 queries.
