I thought it was time to take another look at the Remora that I have been building from the free magazine plan as I have not looked at it since I run out of Humbrol French Blue paint during the early days of the first lock-down.
The hull and the super-structure are finished (but not fully painted !) so I just wanted to add a shelf to hold the ESC and another to hold the rx, drill the holes for all the wires to connect the motor to the ESC (in different compartments) and decide where to locate the LiPos and how to hold them securely.
I made a small shelf with supports to hold the ESC against the rear of the bulkhead that divides the "engine bay" from the next compartment with a pair of supports to stand on top of the keel doublers.
The ESC shelf was made slightly too wide, so I passed it though the bandsaw to cut off a narrow strip to make a shelf (with supports) to mount the receiver onto and fixed it onto the bottom skin on the opposite side to where the steering linkage will run.
The three wires complete with 6mm gold connectors were passed from the mounted 90A SeaKing ESC through to the engine bay where (fortunately) the guesstimate worked out OK and the wires were just long enough to connect them to the Turnigy D3536/6 1250 brushless motor wires.
This motor is what I usually refer to as the "aero-type" because the greater part of the rotating motor body is mounted in-front of the motor mount so it is mounted further forward in the hull than would be the case with any of the other brushless motors that I am using.
This is the one installation that defeats my "universal" inter-changability of any motor in any hull system, but if it does not perform well enough I will cut the mount out of the hull and re-position it to accept any of my other motors. The ESC can be used in any hull as it has been fitted with the 6mm gold connectors that I use to connect every motor and ESC together.
I found an old brass rudder assembly that is probably of the same vintage as the Remora plan. The rudder is quite large and should suite this "steering design" quite well, so I cut the threaded brass mounting boss down a little and fitted a 5mm brass collar onto the shaft to prevent it dropping out if I should ever suffer a loose steering horn clamp when he boat is out on the lake.
I think I can mount two LiPo cells length-wise under the ESC shelf but I have not decided how to hold them securely yet, and I need to modify and finish the steering servo mounts so they will be my next jobs to do on the Remora..........and keep looking for some paint!
