Author Topic: two questions  (Read 2417 times)
Rob47
two questions
« on: October 14, 2019, 02:29:16 pm »
Any suggestions for a fairly soft wire that would replicate at 1/96, the wire used on davits, CVA-01 has davits that extend horizontally from the respective boat decks, so need something that will be fairly rigid but not over so.
Secondly does anyone do at same scale the black and yellow edging strips, though BEC might but no lick
I will finish this model
frogman3
Re: two questions
« Reply #1 on: October 17, 2019, 10:23:56 pm »
HI Bob  well first question go into a fishin shop an look at the wire they got in their what the fish cant bite through that's where I get my railings wire from
an yes I think becc does the yellow an black in severall scales
chris
RST
Re: two questions
« Reply #2 on: October 17, 2019, 10:34:45 pm »
You can  print your own waterslide transfers easy enough. Info all over the web.
For wire what diameter? I'd be looking at anything, if you desire a specific config can always consider wind it yourself in a drill and vice?
frogman3
Re: two questions
« Reply #3 on: October 17, 2019, 10:41:00 pm »
HI Rich now Bob says its for a 1/96 scale so its gonna be very thin but he needs sturdy wire as well  hence fishin wire
chris
raflaunches
  • The Penguins are coming!!!
Re: two questions
« Reply #4 on: October 17, 2019, 10:43:59 pm »
Might be worth checking out what Albion Alloys have in their catalogue. I use 0.2mm Nickel Silver Rod for hand rail stanchion wire but Iím sure that they do 0.2mm dia brass rod too.
Nick B
Illegitimi non carborundum!
tonyH
Re: two questions
« Reply #5 on: October 18, 2019, 11:28:25 am »
Silver plated jewellery wire from 0.2 to 0.6 are relatively cheap and I'd assume solderable with the silver plating
Rob47
Re: two questions
« Reply #6 on: October 18, 2019, 11:36:02 am »
Chris
if you have a link to Becc doing that black/yellow, be very grateful, spent ages looking, they only do one type and its not that
chris
Rob47
Re: two questions
« Reply #7 on: October 18, 2019, 11:36:45 am »
Yep I know I can and have done but was hoping that BECC did them
frogman3
Re: two questions
« Reply #8 on: October 18, 2019, 01:33:39 pm »
HI Bob here is the web addy www.becc.co.uk  an tel no 01692652960
mobile 07787025484
an yes becc does the yellow an black deck markins in 1/72 an 1/96  scale an a pic link below  hope this helps you bob
chris
https://ibb.co/bg0MZ0H
Rob47
Re: two questions
« Reply #9 on: October 19, 2019, 01:45:34 pm »
Cheers Chris
Have put some on order to see if it does the job
mobile 07787025484
chris
frogman3
Re: two questions
« Reply #10 on: October 19, 2019, 04:27:51 pm »
Cheers Chris
HI  Bob when you come to fit them don't rely on their stickyback as they will soon lift I had to glue mine down with pva  hope this helps you
chris
