Model Boat Mayhem - Forum
Author Topic: robbe coupling  (Read 316 times)
Klunk
robbe coupling
« on: October 15, 2019, 12:20:37 AM »
new member has a Robbe Najade. the coupling rubber has perished.
any ideas where to buy the rubber?
looks like this
https://www.cornwallmodelboats.co.uk/cgi-bin/ss000001.pl?page=search&SS=r1446&PR=-1&TB=O&ACTION=Go%21
seems stupid to buy a whole new coupling!
WARWICK IS AROUND THE CORNER........WHO IS UP FOR TRICKS ON PHIL?
Re: robbe coupling
« Reply #1 on: October 15, 2019, 12:53:29 AM »
Sometimes marketing takes us all for granted.........are we stupid? or is it the world of Commerce?
The flexible element is obviously made from a byproduct of black gold......
If the owner had the time to spend, a close fitting tube over the two coupling halves, mix and inject a thermo-setting  plastic into the tube & a new element is produced following the exact profile of the lobes in each coupling 1/2......[exhausting of entrapped air would be required]
All versers the cost of a complete new coupling assembly?
Re: robbe coupling
« Reply #2 on: October 15, 2019, 12:56:11 AM »
I'm just wondering whether or not heat-shrink might do the job? - or perhaps a piece of reinforced
 garden hosepipe? This would probably need steeping in very hot water to soften it sufficiently to press fit.
Pop top campervan needed
Re: robbe coupling
« Reply #3 on: October 15, 2019, 07:47:54 AM »
Try Mobile Marine. They do heavy duty couplings.
Re: robbe coupling
« Reply #4 on: October 15, 2019, 08:30:43 AM »
Perished rubber in batch lots?........in 1972, I purchased a new Renault 12 motor vehicle...after 8 years the front shock absorbers became noisy & tended to bottom out....thump...bang, thump >>:-(
Thinking I'll fix this .....I purchased a new genuine Renault replacement set of shockers ....installed them & after 6 months, the condition returned thump...bang, thump
Checked the date of manufacture....   you guessed it 1970.......same as the pair I removed. <*<
Discussed the situation with the distributor who suggested I had incorrectly installed them... :-X
............Perished rubber in batch lots!
Re: robbe coupling
« Reply #5 on: October 15, 2019, 08:45:30 AM »
A slice off a car fuel or heater pipe might do the trick if you can find the right bore. But if you have to buy the pipe thn you might as well get a new coupling designed for the job.
SHG models do some good ones.
ray123
  • mary marie cygnus gm33
Re: robbe coupling
« Reply #6 on: October 15, 2019, 09:07:27 AM »
looks like this
hi klunk  i use them style couplings   and   have found bauer modell in germany  do this kind of coupling and also the rubber middle https://www.bauer-modelle.com/epages/Bauer_Uwe46269592.sf/en_GB/?ViewAction=View&ObjectID=59207528&PageSize=36&Page=2   scroll down to the bottom of the page
Subculture
    • Dive-in to Model submarines
Re: robbe coupling
« Reply #7 on: October 15, 2019, 02:25:53 PM »
Silicone hose works well, doesn’t perish and is very cheaply available on eBay in pretty much any diameter you wish.
coch y bonddu
Re: robbe coupling
« Reply #8 on: October 15, 2019, 06:05:56 PM »
Best one to use is Orange Calor Gas pipe cheap as chips and strong as well  O0 O0 O0 O0 O0
