Hmm, I'm not sure if "rubber" is compatable with styrene constituents but I would agree totally there are different characteristics from different suppliers. Even if it's extruded or rolled makes a difference not all PS is the same -just like EPS/XPS! I would also argue there's probably as much PS hulls out there as ABS (aren't Billings known for ABS though?).
I'm envious of your sidewall hovercraft though. Saw one on Ebay recently but I don't buy on auction even though I've wanted one for years!
Personally I notice that some folk who model in plastic would leve a white plastic component unpainted, whereas others (like me) would still prime it and paint it white. I haven't had much problems over 30 years but then it's all painted and not left sat in the sun.
...There will be some variation in production runs though. I know myself sculpting some PS sheet with a heat gun for something for work last week, when you het it like in vac-forming, it changes properties. I'm sure I took my sheet past the glass transition point last weekend -but don't care, I just wanted to impression something.
There's folk on RC groups advocate reinforcing vac-formed hulls with epoxy and matting. I don't see the point over the full thing personally. Use doublers and solvent in the damaged area, or thoroughly rough-up, de-grease and use some adhesive and reinforcing.
