I too used R14 autocad when I worked at a previous company (sadly now closed - best ever company I ever worked for), I regularly used to astound the MD with the 3D visualisations I created with the solids element of clients building layouts with our equipment inside, I used to only have the walls go a metre above the floor so you could see the equipment and where it went from and to, if there was a beam that went above the ducting - that would be shown to indicate that we had accounted for the obstruction, in fact, I even drew the several floor levels above each other and the duct run for a project in a IRAQ bank, where the main equipment we supplied was in the underground car park and the staff equipment was on the ground floor, but I indicated the structural problem that had occurred under the first floor where the duct was to run, and the open atrium that they expected the duct to cross.
Sadly my youngest wiped the program from my home computer in his zeal to change the motherboard, he could not get it to work with the hard drive and the win 7 installed - so instead of using the spare hard drive in the pc, wiped the main hard drive - idiot.
