Pages: 1 [2] 3   Go Down
Author Topic: FrSky Taranis X9D and X9E / Shannon Builds  (Read 16135 times)
kinmel
Re: FrSky Taranis X9D and X9E / Shannon Builds
« Reply #25 on: December 15, 2019, 09:07:12 pm »
Your version runs correctly in the Sim, so that is another module in the library.
ThanksAlan
The Old Fart
« Reply #26 on: December 15, 2019, 09:09:58 pm »
Add the SF switch to kill the drives. it's labelled 'FkIt'
kinmel
« Reply #27 on: December 16, 2019, 07:06:40 am »
You will get an even faster turn if instead of just stopping the inner motor, you reverse the motor at full rudder.
Try changing CV1 to -75,55,100,55,75.
The Old Fart
« Reply #28 on: December 16, 2019, 08:11:57 am »
I was thinking the same thing, thanks.
The Old Fart
« Reply #29 on: December 16, 2019, 06:34:51 pm »
above reverses only one side.
-75,55,100,55,-75.
kinmel
« Reply #30 on: December 16, 2019, 08:51:37 pm »
yes it does !  missed out the minus sign when posting, it's in the Sim.
Sorry  <:(
The Old Fart
« Reply #31 on: January 04, 2020, 04:46:21 pm »
Trying to get my head around this.
X9E
Using TGY_CVT01 voltage sensors.
If  'read voltage' < 4.00V then radio speaks 'Port Stopped'.
kinmel
« Reply #32 on: January 04, 2020, 05:13:39 pm »
Is the input voltage dropping below 4v ?   If so the unit automatically switches off and the Port will stop.
Voltage Range: 0~100V DCAccuracy: +/- 0.1V
Input Voltage: 4.0~6.5V
The Old Fart
« Reply #33 on: January 04, 2020, 05:31:15 pm »
Not what I'm requiring.
5v for RX's and Servos is from a separate battery source.
Red leads from ESC's are disconnected.
ESC's have a single push button for on / off.
Flick switch on X9E to start ESC,  further flick switch to stop ESC.
By monitoring the red lead will show if ESC is on or off.
Hope that makes sense.
The Old Fart
« Reply #34 on: January 05, 2020, 09:15:19 am »
Found this, need to watch with large mug of coffee...
https://www.youtube.com/watch?v=cK_R4MG7qXY
The Old Fart
« Reply #35 on: January 06, 2020, 06:09:09 pm »
Waiting for frsky voltage modules to arrive.
Experimental program using rx battery monitor.
under 12/13 <discover new sensors>
Logical switch    L01  a<x  RxBt  4.7V
Special functions  SF1  L01  Play Sound  Ratata   1s
                          SF2  SE^ Play Value RxBt  2s        //  speaks voltage
page 13/13  Screen 1 RxBt     Time
to see data screen hold <page>
options also to <play track>
Found sensors in my junk box, to read motor rpm and temperatures, using the Smart Bus
The Old Fart
« Reply #36 on: January 09, 2020, 05:37:52 pm »
RPM, Current, lipo and gps sensors all working to the smart port.
sbus to pwm module works, but not using it at present.
Problem I've got is reading sensors into the sbus and showing on the x9e.
Been searching sbus & x9e but only get the sbus to pwm module.
Do I need to enable sbus inputs in a menu?
tsenecal
« Reply #37 on: January 10, 2020, 05:43:21 am »
sensors do not go into the sbus, they can only go into the s(mart)-port
The Old Fart
« Reply #38 on: January 10, 2020, 08:27:13 am »
That's a shame, the I6x TX/RX setup uses the sbus for sensors.
tsenecal
« Reply #39 on: January 11, 2020, 02:45:39 am »
Flysky != FrSky
but seriously, telemetry/sensors are the "wild west". all the different manufacturers use different telemetry protocols, some have more than one (FrSky D series is different from X/L/R series), and they all use different methods to get the data back to the receiver.  to the point where you will not be able to use a different manufacturer's sensors.   Castle Creations make Speed controls that work with Spektrum OR Futaba, but to do so, you need an adapter (unique to the brand of transmitter) that costs as much as the speed control.   One of the reasons i went with FrSky is because their sensor lineup is very large, and inexpensive.  it also doesn't hurt that their protocol has been reverse engineered, and one can create unique/new/different sensors using an arduino.
from what i have just read, the sensors for the 6 channel flysky receiver will not work with the 10 channel receiver !?!?!
The Old Fart
« Reply #40 on: January 12, 2020, 04:41:06 pm »
Back to my  'speak warning when motor esc off' .
Discovered the Voice Generator for Taranis.
https://www.open-tx.org/2014/03/15/opentx-speaker.
tsenecal
« Reply #41 on: January 12, 2020, 08:20:56 pm »
The Old Fart
« Reply #42 on: February 25, 2020, 04:19:07 pm »
@kinmel,
Presume using mixes > 16 due to only being able to select one switch.
I originaly moved the mixes to ch28-32 to release ch17-27.
Now I'm looking at removing these mixes.
Using Logical switches.
CH2:Pbucket
L02  AND  SFdown    SDup
L03  AND  SFdown    SDmid
L04  And   SFdown    SDdown
then putting in Mix2
thoughts?
kinmel
« Reply #43 on: February 25, 2020, 04:59:03 pm »
I used the virtual channels for mixes because that way it was easier to understand what was happening when mixing 3 switches with 6 inputs to manage 8 outputs and 9 curves. All while knowing nothing.
Since then we have started using logical switches and it does streamline the process, so it is worth making the changes.
I have not done much with Open TX lately, now trying to master 3d printing.  Once the weather improves and the Shannon is back on the water, I will start tuning the boat's handling.
The Old Fart
« Reply #44 on: February 25, 2020, 05:12:28 pm »
Only took me 2 years and 3 3D printers to get a suitable printer, good luck....
The Old Fart
« Reply #45 on: February 26, 2020, 08:33:26 am »
Using the Timer Display.
Displays Throttle running time.
L14_____a~x_____Thr____0
Timer 1    !L14
The Old Fart
« Reply #46 on: September 04, 2020, 06:58:57 pm »
Does anyone know where I can get this part for a x9e?
It latches the retractable legs in place.
Taranis
  • Balne Moor MBC
« Reply #47 on: September 04, 2020, 07:05:46 pm »
ANDY
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
« Reply #49 on: September 04, 2020, 07:23:02 pm »
ANDY
Pages: 1 [2] 3   Go Up
Page created in 0.036 seconds with 21 queries.
