Author Topic: Build log of Vosper Fast Patrol Boat from Fleetscale  (Read 4238 times)
Jim Pinner
« on: December 30, 2019, 01:34:53 pm »
Firstly forgive my ignorance in the workings of this forum.
Finished the 1/12th Severn and VAC II refurb.
Just started a new build of Fleetscales semi kit of HMTS Trinity CG2. Will log my pics so far once i've downloaded them, i have some on Facebook under MBM Group, but i'm going to try log my progress on here to.
Re: Build log of Vosper Fast Patrol Boat from Fleetscale
« Reply #1 on: December 30, 2019, 01:54:20 pm »
I am looking forward to this Jim.
I have never seen one of these on the water.
Jim Pinner
« Reply #2 on: May 17, 2020, 01:11:46 am »
Made some good progress on this build, attached are a couple of early pics as I’ve just worked out how to add photos (I think)
Jim Pinner
« Reply #3 on: May 17, 2020, 01:18:50 am »
WoW it worked ok so I’ll keep posting my progress so far as I’m a couple of months on from here now
« Reply #4 on: May 17, 2020, 01:45:02 am »
Following on Jim  :-))  ....will the rudders be removable to withdraw the prop shafts....[as usual for the prototypical craft?]
This is for the unplanned leaking stern shaft seal or seized shaft bearing etc
The propulsion hardware looks to be of good quality.....are these from the standard kit?
Jim Pinner
« Reply #5 on: May 17, 2020, 07:44:07 am »
Hi Derek, yes the rudders are removable, I’m going to create an inspection hatch for access.
Yes the running kit came as part of the original order, will more pics now I know how to!
« Reply #6 on: May 17, 2020, 10:33:18 am »
I do like the running gear.
Jim Pinner
« Reply #7 on: May 17, 2020, 11:06:56 am »
Pretty aren’t they
Jim Pinner
« Reply #8 on: May 17, 2020, 11:12:57 am »
Some more pics
Dave_S.
« Reply #9 on: May 17, 2020, 01:22:29 pm »
Is this similar to the old Veron kit of the Vosper FPB? I had one of them a good few years ago now, built by a friend who passed it on to me. Had a single MFA Barracuda motor if I remember correctly, and two lead acid batteries, weighed a ton but had real presence on the water.
RHBAKER
« Reply #10 on: May 17, 2020, 05:05:42 pm »
Nice looking hull with good running gear, should turn out very well.
Have tried to see what spec. the motors are, but cannot quiet turn my head around far enough!
Could you advise the size and kv rating please - should both be on the label.
Am starting the build of a 27" long, twin screw pilot boat and have been toying with using 2 x 2845 2800 kv  brushless motors left over from another project.
[size=78%]Suspect it will be vastly overpowered so am thinking of getting something smaller, rather like what I think yours are.[/size]
Rowen
Jim Pinner
« Reply #11 on: May 17, 2020, 07:08:48 pm »
Hi Rowen they are Turnigy 2 x 2836 2500 kv, nice motors, got a pair of these in my Virgin Atlantic Challenger.
RHBAKER
« Reply #12 on: May 17, 2020, 07:40:49 pm »
Hi Jim,
They look good.
Much the same output the ones I have though, might be better off just to use them and see what happens.
Rowen
Jim Pinner
« Reply #13 on: May 17, 2020, 09:17:26 pm »
Some more pics of my progress so far
« Reply #14 on: May 18, 2020, 09:01:15 am »
Looking Good.
« Reply #15 on: May 21, 2020, 10:25:17 am »
She's coming along really nicely. The RIB is a sweet little model in it's own right  :-))
