Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23]   Go Down
Author Topic: David's Amati Riva Aquarama Build - With some mods...  (Read 170455 times)
DJW
Re: David's Amati Riva Aquarama Build - With some mods...
« Reply #550 on: September 12, 2023, 10:57:09 am »
Hi All
An update as it's been a while...
Not had the 1/10 out as much as I'd liked this year, and missed a few Open Days for various reasons.
She's had some outing's to Bushy Park:
And did make it up to the excellent Wicksteed MBM event back in May:
Have had a bit of a problem with the port prop shaft, a nasty vibration at anything over half power.  Investigating it, I can see the prop blades are now marking the hull paint...  Not good.  I can see the Teflon washer between the prop and the P bracket has worn and thinned, but I thought the thrust was being transferred to the motor mount by a fixed collar on the shaft, well I've obviously screwed up it seems.  This has brought the blades closer to the hull.  Still find it odd that its after half power that the blades strike the hull...  Can the bronze blades really be flexing...  Or maybe the Teflon washer just compresses more under load, I think that's more likely.
It's one thing diagnosing the problem, another matter fixing it...
I made a few mistakes putting the drive lines together, (hindsight is a wonderful thing...) I used red threadlock on the various 3mm grub screws that hold props and collars onto the prop shafts.  Big mistake, that's the permanent one, should have used blue.  Had a lot of trouble getting the shafts out as some of the collars were very tricky to reach, and very tricky to get the grub screws out...  If you google how to remove red threadlock, best suggestion is heat to 350 degrees, not ideal.
But I've now got the boat on the bench, shafts out, had to drill out the grub screw on one of the props.
Plan is to rebuild with slightly smaller props, and use blue threadlock...
Very best regards to all.
David.
« Reply #551 on: September 12, 2023, 02:24:31 pm »
Hi there David, I've been 'off-air' for a number of months as well, slowly getting caught up with things.
That's some serious problem you've had, but at least you have a plan of action to rectify / repair it.
Aye,
« Reply #552 on: September 12, 2023, 09:41:10 pm »
Yes David........obviously the Teflon has extruded/or and thinned under rotational load......running the motors out of the water could also created a heat greater than the teflon is suitable  for?
The solution will be a stainless washer running against the bronze/brass...and water will be the lubricant......the bronze blades will not have been flexing
Again, in hindsight, any running out of the water,   %)  would be advisable for a few drops of oil at the washer/bronze interface
A well-known Asian manufacturer of steam products was using Teflon flat-faced washers in the banjo fittings of his piston water pumps
The Teflon extruded and wept and I could not attain @ 3 Bar when pumping up a cold boiler .......just a continual bubbles or drops of water from under the pressure side of the Teflon washers, I changed out the Teflon washers for Red fiber washers......problem solved
The revised design by the Manufacturer is now captive o-ring seals........
I have two of these pumps, however my discussions ended abruptly when I requested some sort of retro-fit, as I suggested the original design was defective <*<
So obviously Teflon has it's place, but not in your application....nor sealing in water pumps >>:-(
« Reply #553 on: September 13, 2023, 10:00:43 am »
Any chance the hull is flexing around the prop struts allowing 'whip' when increasing revs due to prop pitch?
 Regards Ian.
DJW
« Reply #554 on: September 13, 2023, 04:36:01 pm »
Hi All
Thanks for the comments.
@Ian. I don't think the P brackets or their mounts are flexing, I think if they were it would have been a problem from day one.  And looking at the surrounding areas there's no paint crazing or stress marks that I can see.  I've checked the shafts and they seem to be running true, your thought did make me wonder if I'd bent a shaft.
@Derek. I'll be using stainless washers for sure going forward.  I think I was surprised about the Teflon for two reasons.  1. It shouldn't have been taking any force from the prop...  2. I don't remember them wearing quite so badly so quickly...
@Ray.  Good to hear from you, I think everyone's build take a slow down over the summer...  Never mind, a nice dark winter to look forward to now..!!
I'll report back once the fixes are in place and tested...
David.
ChrisF
  • What's my favourite cake!
« Reply #555 on: September 14, 2023, 04:49:30 pm »
Hi David
That's a shame about the paintwork, hope you can patch it up Ok. Your props must be running very close to the hull for that very small amount of movement to cause contact? I note you're going to use smaller props now.
Chris
DJW
« Reply #556 on: September 14, 2023, 05:03:17 pm »
Hi Chris
Yes...  With hindsight the prop blades were too close to the hull. When I built the boat I wanted a nice shallow angle for the shafts, but maybe went a bit too far, compounded by initially underestimating the prop size that the motors could spin. So when I put the slightly larger props on, the performance went up, but the blade clearance went down. But to be honest the smaller props will be fine, better clearance and still a scale speed. Putting the boat back together now and looking forward to getting her back on the water..!
Very best regards
David.
JasonRC
« Reply #557 on: May 09, 2025, 06:45:15 pm »
Afternoon All
Just spent a couple of hours on the Riva. Got the windscreen conformed to the correct curve and the deck drilled to take it. Also the various upholstery panels finished and in place.
Regards to all
David.
Firstly David this had been a great source of information for me  and it's a stunning model. I've been doing my own scratch built Riva for several years. I'm struggling with the screen, so have been considering the Amati Screen and seats 'kit' but the screen looks a little flat at the front. Obviously this needs to sit nicely around the curved deck, and I note you said you formed it around.
How much forming did you have to do? I am wondering as well if you wouldn't mind sharing some approximate dimensions....mainly the width?
Jason
DJW
« Reply #558 on: May 12, 2025, 12:56:10 pm »
Hi Jason
Really pleased to hear that the build log has been useful, and very happy to assist with pics or dimensions of the windscreen.  I'll drop you a DM to start the ball rolling.
And you've reminded me to update these pages with the results of the vibration problems I was having, and the eventual solution.  Turned out to be the plain bearings at the lower end of the prop tubes, where the tubes exit the hull and the shaft becomes exposed.  I used steel/teflon bushes as used on multi boats, but seems they've worn, I could feel some play so they had to come out...
I made up a tool to hook over the bushes, then a brass 'slide hammer' to get the bushes out.
I had a bit of an adventure extracting them, then replaced them with longer (20mm ish) bushes machines up from engineering plastic (formulated for low friction bushes).
The boat is now back together and it's now vibration free.  She was at the Popham model Show (near Basingstoke off the A303) on the Portsmouth & District Model Boat Club stand.
Next outing will be up at the MBM Wicksteed event at the end of the month, looking forward to it..!
Best regards to all.
David.
JasonRC
« Reply #559 on: May 12, 2025, 03:58:14 pm »
Thanks David,
And interesting tool to taking the bushing out!
Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23]   Go Up
