Thanks for the encouraging comments both. Re the windscreen, yes I think that's how I'll tackle a self build version, template to get the deck curve, then brass sheet, and chrome it.
Had the Aquarama out on the water today for another run, sun was out and the hull really lights up..! Bushy Park this time.
It was a bit cold, so no video this time as I was on my own, just a couple of phone pics.
Generally pleased with the outing, was playing for about 40m before the 3,000 mAh batteries had enough. ESC temp didn't exceed 40 degrees, so very pleased with new cooling measures. Current didn't exceed 8 Amps per motor, so I could up the prop pitch again, or shift to a higher gearing, its 3:2 down at the moment, might try it at 1:1, motors are rated at 30A... Gearbox was mainly intended to get a low shaft angle. Think I'll wait to see if adding the skier loads the motors any more before doing anything. Still a bit unhappy with the whine of the motors. I think its me opting for the solid mounted gearbox with ball races... So my own fault. It's not excessive, just irritates me. I'm thinking to get the boat finished in all respects for the summer, then think about motor mount alternatives next winter... Maybe.
Max speed on this outing was 24km/h, looked fine on the water but below what it should be doing. Weight is about 4.3kg, and until she's planing the bow does look heavy... Anyone building this kit for RC use really needs to build her light. Andy (Taranis) went further than I did with weight saving, wish I'd shaved off more during the hull building stage.
But very pleased overall, and great to get her on the water where she belongs.
Best regards to all.
David.
