I enjoy sailing in moving water.
There used to be a creek nearby, where you could sail up stream, and then hover, as
you found, using just enough power to match the current. Then use the current to whip the
bow around and speed down stream. Only to turn up stream again and play some more.
Never did a maneuvering course, but we always wanted to try a Kayak style maneuvering challenge.
Where the skipper had to sail upstream through some gates, downstream through other gates, and
Backwards downstream etc.
The other thing we had planned once, was to put a fairly large pump into the pond so that docking maneuvers
would be situated in a moving current. We ran out of time that day, and didn't get to that challenge. But a
small amount of current changes boat handling characteristics and would make for a fun day at the pond.
