Author Topic: Using twin ESC's  (Read 4026 times)
ukmike
Using twin ESC's
« on: January 11, 2020, 01:24:55 pm »
Hi.
There is a lot of differing information on the net regarding the BEC when using 2 or more ESC's, much of which is contradicting the other.
Have just received definitive information regarding the the BEC's for a twin,(or more), setup.
If the BEC supply from the ESC is a switching type then only 1 can be used as Rx supply, however, the unused BEC supply can be used for other purposes,
i.e lighting, small brushed motors, pumps etc. up to the BEC's max current.
The information came from the Flycolor factory tech. dept. but does not apply to ESC's that use a linear BEC.
May help.
Mike.
Re: Using twin ESC's
« Reply #1 on: January 11, 2020, 02:26:51 pm »
..... however, the unused BEC supply can be used for other purposes,
Yes, that's how I understand it too..... just make sure secondary circuit is isolated, no +ve 'sneak' circuits!   :-)
« Reply #2 on: January 11, 2020, 02:49:40 pm »
This will only apply to esc's for brushed motors, but not for brushless. ..??
ukmike
« Reply #3 on: January 11, 2020, 03:05:47 pm »
Hi Ned.
The information is for Brushless ESC's, the majority of which have Switching type BEC's. The only one  that I know of that allows using both BEC's to be  used
is Castle Creations, but you need to save up to buy one.
Brushed motor ESC's, I don't know.
Mike.
« Reply #4 on: January 11, 2020, 04:28:23 pm »
Hey Ned!   :-)
 Wasn't there a long debate on here, some time ago, about using a twin bushless speed controls?
Edit: Sorry that was, 'can you use two brushless motors on a single controller' ...... but I don't think that's relevant here!  :embarrassed:
Nordlys
« Reply #5 on: January 12, 2020, 09:50:16 am »
Staying within this thread , I hope, do I need two batteries when using two brushless Esc's on twin brushless motors?
If no, what would the connection be.?
N
« Reply #6 on: January 12, 2020, 10:07:08 am »
Without knowing the exact working of both BECs involved, the only safe answer is "don't".  No doubt there are specific instances where multiple BECs can feed into a common supply, but there are still plenty out there which react badly to being presented with a wrong voltage on their output.
Having just one BEC working the system avoids the possibility of having to buy replacement parts.  The "unused" BECs are still doing work - they supply the 5 volts that the input end of their ESCs need.
[size=0px]Staying within this thread , I hope, do I need two batteries when using two brushless Esc's on twin brushless motors?[/size][/size][size=0px]If no, what would the connection be.?N[/size]
Depends on the battery or batteries, and what they are capable of supplying.  If the two motors, at full load, want more current that one battery can supply, it won't work.
One big battery per system, either a suitable Y lead for the power or a proper distribution panel.
One suitable battery per ESC, just plug each ESC into its respective battery.
DaveM
  • Why on earth do I do this?
« Reply #7 on: January 12, 2020, 11:42:03 am »
While I can see the possibilities of using a "spare" 5v BEC output I'm bound to say that, in order to do so, you really do have to understand exactly what you're doing and what the possible consequences are. My experience of making and selling model boat electronics and dealing with the customers is that not many boat-modellers have that level of understanding. For example, how do you tell the difference between a switch-mode voltage regulator and a linear one, particularly if the ESC is completely "potted" or built entirely of SMT components? (No - please don't post if you do happen to know - that's not my point.)
I'm therefore with Malcolm on this one - if in any doubt, don't.
BTW does anyone know how to make the Spell Check option on this forum work?
DaveM
Taranis
  • Balne Moor MBC
« Reply #8 on: January 12, 2020, 11:50:38 am »
I'm not sure there is one Dave. I think it's part of whatever Browser the typist is using.
Edit
I've just checked my Safari "apple" browser and the "correct spelling automatically" is in the Keyboard Text settings
ANDY
« Reply #9 on: January 12, 2020, 12:15:36 pm »
Taranis
  • Balne Moor MBC
« Reply #10 on: January 12, 2020, 12:17:24 pm »
 :embarrassed: {-) {-) {-)  I never noticed that  %%
ANDY
« Reply #11 on: January 12, 2020, 12:58:24 pm »
It's not that great but helps!
DaveM
« Reply #12 on: January 12, 2020, 01:34:31 pm »
Then please tell me how. I've tried first highlighting text as a block, then just single mispelled words and even clicking the button with nothing highlighted. Nothing seems to happen apart from the text becoming white out of a grey box.  <:(
DM
« Reply #13 on: January 12, 2020, 02:38:55 pm »
I'm using Microsoft Edge and spell check works, it also works on Chrome and Firefox. Right click on underlined word give suggestions. I can't find any option on spell check within the Edge browser.
DaveM
« Reply #14 on: January 12, 2020, 03:41:58 pm »
Thanks for that suggestion, but the problem isn't a general one of checking my spelling. There are several spell-checkers already available to me in different bits of software on this PC, as well as the one installed in my head.  it's just that there appears to be one built into this Forum but I can't get the damned thing to work!
These things are just sent to try us, I guess....
DM
tsenecal
« Reply #15 on: January 12, 2020, 08:16:37 pm »
N
a Y cable that connects to one battery and two ESCs is possible...
ie, something like this -  the 1M2F version:
https://www.ebay.co.uk/itm/T-Plug-Deans-Y-Wire-Harness-Parallel-Adapter-Cable-for-RC-Li-ion-Battery/222129123029?hash=item33b7ed6ed5:m:mQSK44mfSSa5secrNg0CeqQ
ukmike
« Reply #16 on: January 12, 2020, 08:42:22 pm »
Hello tsenecal.
You can do that but don't forget to cut the Red wire on one of the ESC BEC wires.
Mike.
john44
« Reply #17 on: January 12, 2020, 10:24:16 pm »
Don't cut the red wire, remove it from the connector bend and tape it to the esp lead.
You may need to refit it in the future.
Peter Fitness
« Reply #18 on: January 13, 2020, 05:13:56 am »
Dave, the spell check on Mayhem works for me. If I spell a word incorrectly it underlines that word with a red dotted line. Clicking the word, or tapping it on a touch screen, brings up a selection of words to choose from. It works just as well on the iPad, PC, or phone. However, if yours doesn’t work then none of what I said is much use to you😬
Peter.
« Reply #19 on: January 13, 2020, 07:27:34 am »
You may have the Moderators version  Peter ____ ----- _word ___ {-) ?............ Derek
DaveM
« Reply #20 on: January 13, 2020, 08:14:59 am »
Peter.
Nope - nuffink. Then again, if it does that then what's the button for? BTW   {:-{    I use Firefox as a browser.
DM
« Reply #21 on: January 13, 2020, 08:47:01 am »
czecking spell czekker
Press button, a brief wait, a smaller window pops up with the messagem first word highlighted.  Clicking "ignore" and hoping it isn't learning, it moves on and highlights the next questionable word.  Using a laptop running chrome in Win 10.
Nordlys
« Reply #22 on: January 13, 2020, 09:08:43 am »
With regard again to using two esc''s I have been running with two motors, two batteries and two esc's but I haven't removed any bec connections?
What effect am I to find then if I do remove one?
I'm planning on using a 'y' lead in order to use just the single battery.
Nord.
ukmike
« Reply #23 on: January 13, 2020, 10:43:18 am »
It could be that your ESC's have linear voltage regs. which are more tolerant, if it ain't broke don't fix it.
Don't know if using a Y lead and 1 battery will effect anything as they then will be using the same ground.
Personally, I would disconnect one of the BEC Red leads just to be safe.
DaveM
« Reply #24 on: January 13, 2020, 11:16:16 am »
Nord
The purpose of BEC is to provide power for the receiver from the main power battery. The receiver only needs one power supply and by presenting it with two, which may be at different voltages, you are not solving a problem but potentially creating one. You've simply been fortunate so far. Disconnecting the red wire from one of the speed controllers will remove this potential problem and have no discernable effect on the performance of your system at all.
I'm afraid that I don't understand your last sentence. Connecting the two ESCs with a Y-lead will not of itself remove the need for one of the main motor batteries. As someone has said, you're best advised to keep it simple with two of everything - just disable the BEC in one system.
DaveM
Page created in 0.111 seconds with 21 queries.
