Author Topic: Tear out and chipping when cutting plywood  (Read 1116 times)
dave parker
« on: January 17, 2020, 08:20:54 pm »
i have just cut out my springer hull prices from 6mm plywood and have got a lot of tear out and chipping along the edges, only on the top side though
I think I may have the wrong jigsaw blade
Is this a common thing?
Obviously it can be fixed later when sanding and filling the hull for paint
Any suggestions?
grasshopper
    • A1 Hobbies Ltd.
Re: Tear out and chipping when cutting plywood
« Reply #1 on: January 17, 2020, 08:37:43 pm »
A finer blade with a slower feeding of the work piece into the blade,
Running a sharp blade along the intended cut line, then sawing away from the line and sanding to it.
RST
« Reply #2 on: January 17, 2020, 08:59:52 pm »
Put masking tape over the cut on the pull side of the blade. If the line isn't visible enough when cutting re-trace it. You'll almost always have an "edge" when cutting.
tonyH
« Reply #3 on: January 17, 2020, 09:46:07 pm »
Reverse the sides so the decent sides are on the inside. It's common, especially if the ply is a tad old. :-))
« Reply #4 on: January 17, 2020, 10:12:13 pm »
I usually use a hacksaw blade in a jigsaw when cutting plywood. It gives a better cut.
dave parker
« Reply #5 on: January 17, 2020, 10:26:32 pm »
Thanks Tony, thatís a good idea, then prep he outside before paint
Thanks Colin, sounds interesting. Do you cut the blades in half before fitting in to jigsaw?
« Reply #6 on: January 17, 2020, 10:33:07 pm »
I use jigsaw hacksaw blades. The fine toothed ones.
chas
« Reply #7 on: January 17, 2020, 11:36:01 pm »
With dodgy wood I cut outside the line and sand back to where I need to be.
Chas
« Reply #8 on: January 18, 2020, 02:51:41 am »
There are special jigsaw blades for cutting plywood.
They have a higher number of teeth per inch (TPI), and they have a slimmer blade to make cutting curves easier.
They are not expensive.
If you use masking tape, the blue stuff has a glue that should not leave a residue.
canabus
« Reply #9 on: January 18, 2020, 07:15:06 am »
Hi Guys
I use Makita double cut blades which a cut like a planner blade.
Two numbers on the packet No.10S and A-85824.
My Makita is an old one, but they have blades for the newer ones.
TOTALLY RECOMMEND THEM !!!!!
All my old wood cutting blades are in the rubbish bin.
CANABUS
