Results of last nights efforts and a bit this morning, I have cut all my leg sections out, the hollow ones are for landing legs, top 2 sections of each front leg are glued on now, still to do a bit of carving but the front leg shrouds weigh 11g for the pair... not bad. There are another 4 legs to finish carving, then sanding, I expect weight to be up by about 30-35g, as the copper wire joints are 5+ g, I have some sections carved but a good few bits still to do, nothing has been sanded yet. 6 legs, 18 sections, 72 bits of balsa, all from my scraps boxes. Sanding will make all the difference, they have only had the edges sliced off with a scalpel and they look not bad already. Glad I went for this method, I am quite impressed by the extra effect it gives, it wasnt difficult, just time consuming and required a steady hand for carving, having to direct my cuts carefully to avoid slicing too much off, or pulling into the grain and lopping any spikes or hooks off. Need to give my old wrists a rest for a while now tho, was a long time of constant carving, after a long time of sawing and hunting my scraps boxes. I want to get the right centre leg carved, so I can see a full side done, then that will leave just 2 to do.😁 Yeehah.
Sanding should be bit easier. Just loads of it, and fiddly too.
