Author Topic: Caulking for 7mm planks  (Read 2032 times)
Nordlys
« on: February 20, 2020, 09:28:44 am »
I'm looking for a suitable caulking material,/ method, in black , for use between 7mm X 1mm planks. Any suggestions please.
Thanks.
Nord.
terry horton
Re: Caulking for 7mm planks
« Reply #1 on: February 20, 2020, 09:54:24 am »
I used good quality coloured card for the caulking on my recently rebuilt Seekadet.
Both deck planks and calking were glued with PVA , sanded and varnished to a tough finish.
I' hope to post a couple of pics of this boat once I've fathomed how.
Terry H
Nordlys
« Reply #2 on: February 20, 2020, 10:18:44 am »
In order to post your pictures you will need to get on to the Reply page first, then press the green icon to get started.
Follow the instructions to agree content etc then sign up for an account.
That's enough to get going with.!
N
Jerry C
« Reply #3 on: February 20, 2020, 11:16:34 am »
I used plasticard A4 sheet cut into narrow strips. I mainly work with superglue.
Jerry.
grendel
« Reply #4 on: February 20, 2020, 12:51:48 pm »
I used a pyrography tool to burn the caulk lines into 1/32" ply which I used to cover my decks
john44
« Reply #5 on: February 20, 2020, 12:53:16 pm »
As said above good quality black or white card. Thin cover of glue on the card then place the planks
Side down onto the board. I usually do 6 boards at a time, when the glue has set cut the card
In between the planks with a scalpel type craft knife. Do 1 edge and 1 side only, use the glue
Carefully you don't want the planks sticking together.
grendel
« Reply #6 on: February 20, 2020, 01:00:24 pm »
you can see the planks in the foreground in this picture
Nordlys
« Reply #7 on: February 20, 2020, 01:10:57 pm »
Thanks for the suggestions here, surprising how many methods can be found!
N.
Howard
« Reply #8 on: February 20, 2020, 01:51:27 pm »
Hi Nord,
I have heard that some modelers use black thread pushed between the planks some also use a black marker pen run down the edge  as you have found out  so many ways.
                       Regards Howard.
