Author Topic: Admiral Levchenko 1:200 ( card )  (Read 830 times)
Martin [Admin]
« on: March 01, 2020, 05:37:52 pm »
Another  impulse ebay buy - Russian destroyer Admiral Levchenko - Card / paper model - 1:200
Note: The product is printed color A4 paper, not the finished product, you need to manually cut and install it. This product belongs to DIY manual paper model product.
Specifications:
Painting style: color.
Scale: 1:200 (approx 82cm)
Size: A4 Standard Version (ratio 1:200, when you make good, about 82 cm long).
Difficulty: Level 5 (6 is the most advanced and the most difficult).
Feature: High simulation
Color: As picture
Material: Paper
Size: about 82 cm/32" (when you make it).
Net weight: no cardboard, about 0.36KG, containing cardboard, about 0.59KG
Features:
- It was not finished product, it need you to cut, paste and assemble.
- The cutter and glue are not included.
- Non paper components, such as ropes, are not included in this set.
- It's about 82 cm/32" (when you make it).
Guide to build :
Basic steps to make Paper Models.
1) Cut out each part roughly.
2) Use a pencil to mark note softly behind each part to avoid disorder (Don't use a pen as it probably makes damaged trace on the front side).
3) Use Scissor or Craft Knife to cut parts precisely by following the outer edge. The level of precision affects the effect of combination. (Cut the most outer edge if the line is thick).
4) Smear white adhesive cement on one of the 2 parts which needed to be stuck together.
5) Stick them together until the cement bone-dry.
Suggested tips:
A. For Scissor cutting, suggest not to push the Scissor but pull the paper.
B. To make the fold of parts better, please put the part firmly on the table, and put the ruler on that to fold the line. If you have to fold inside, you could first fold it softly outside to make the trace, and fold it back to inside then.
C. To make the curved parts better, place the part on the corner of table then push and pull it back and forth.
D. To make parts like cylinder, use tools such as pen to assist to make the curl more natural.
Note:
1.The paper model requires you to cut, paste and assemble your own models, more parts,there are schematic drawings, difficult, suitable for senior enthusiasts to produce.
2.Please allow 0.5-1 inch difference due to manual measurement. (1inch=2.54cm)
3.The color of the actual items may slightly different from the listing images due to different computer screen, thanks for your understanding.
Package Included:
1 x 1:200 Battleship DIY
Howard
Re: Admiral Levchenko 1:200 ( card )
« Reply #1 on: March 01, 2020, 09:38:01 pm »
Go on Martin,
get a SD14 Regards Howard.
Martin [Admin]
« Reply #2 on: March 01, 2020, 10:16:43 pm »
