Author Topic: Card TID Tug  (Read 10242 times)
Re: Card TID Tug
« Reply #25 on: March 30, 2020, 10:48:37 am »
The bottom plate doesn't sit flat... would it be OK to put a slits down the middle and glue it down?
Re: Card TID Tug - Part 5
« Reply #26 on: March 30, 2020, 04:54:35 pm »
Sole plate has pronounced 'bow' in it after my last efforts,
 Lets try and fix that ......... this isn't going to be pretty!
'Stuck myself to the model again' count:
 Today = 4
 Total = 19
Howard
Re: Card TID Tug
« Reply #27 on: March 30, 2020, 05:02:11 pm »
Looking good Martin,
 get it finished then do another three then maybe you cant tow my sd14.
           Regards Howard
Re: Card TID Tug
« Reply #28 on: March 30, 2020, 06:58:07 pm »
 Yeah!   {-)
Re: Card TID Tug
« Reply #29 on: March 31, 2020, 05:24:19 pm »
Second / outer layer of hull plating.
Stuck myself to the model count:
Today = 3
Total   = 22
Re: Card TID Tug
« Reply #30 on: March 31, 2020, 06:39:10 pm »
I warned you the glue was good spent, 20 mins stuck to my granddaughters playmobil gallon (I was just trying to improve it ).....panic not dear readers all family isolated together  :-)
Re: Card TID Tug
« Reply #31 on: March 31, 2020, 07:09:24 pm »
Oh I so reconise the super glue activator.........do you need more (and cyno ) as I still have a very large stock......of course I am in lockdown in France..but after we get our freedom back..... :}
Looking for something else ( the way I always find things I'm not looking for! ), I've found 2 more bottles, so I'm good for now Phil!   :-))
 Love to Steff & family.  :kiss:
Howard
Re: Card TID Tug
« Reply #32 on: March 31, 2020, 07:18:10 pm »
Hi Martin,
 Delux materials Roket Card Glue is what you need what am using on that big ship your going to tow.
                Regards Howard.
Re: Card TID Tug
« Reply #33 on: March 31, 2020, 08:10:24 pm »
Now he tells me!   <*<
 Let me check to see if they're open through the 'duration'!
coch y bonddu
Re: Card TID Tug
« Reply #34 on: March 31, 2020, 08:50:10 pm »
YOU are a danger to yourself remember that fateful day i telephoned YOU ad YOU stuck the telephone to you HAND
check your messages
RST
Re: Card TID Tug
« Reply #35 on: March 31, 2020, 09:51:52 pm »
Make sure you have a bottle of nail varnish remover handy when you're working with CA a lot, just in case (just make sure it contains acetone).  In any case, warm water and not panicking helps otherwise if things you don't want on your own apendages get stuck.
I've started to use micro tip applicators with thin CA.  They're cheap enough for a pack.  It helps place a dot much, much better.  Luckily they all seem to have standardised on CA bottle tip size because the applicators seem to fit all the bottles I have from all sorts of places so far.
Keep with the build, it's intersting to watch.
Cheers,
Re: Card TID Tug
« Reply #36 on: March 31, 2020, 10:26:41 pm »
Hi Martin,
                Regards Howard.
NB: Is this stuff any good for card / paper models?
RST
Re: Card TID Tug
« Reply #37 on: March 31, 2020, 10:31:06 pm »
Quote from: Howard on Today at 07:18:10 PM
    Hi Martin,
                    Regards Howard.
The model railway guys like this stuff for card buildings -I have a tub somewhere, it doesn't seem much different from PVA to me.  Roket Card Glue from Deluxe is a bit different -it's a bit like CA and sticks really quick.  Bit strange stuff.
Howard
Re: Card TID Tug
« Reply #38 on: March 31, 2020, 11:12:01 pm »
Martin Honest you'll be very pleased with the Roket glue the bottle go's a very long way it's the best stuff I have found.
           Regards Howard.
Re: Card TID Tug
« Reply #39 on: April 01, 2020, 02:38:33 am »
On order from Amazon - £8.50  :o :o :o
coch y bonddu
Re: Card TID Tug
« Reply #40 on: April 01, 2020, 10:02:16 am »
you have been conned m8 £6.76
https://www.buffersmodelrailways.com/deluxe-materials-ad-57-roket-card-glue-50ml
I never use amazon as they far to expensive
Howard
Re: Card TID Tug
« Reply #41 on: April 01, 2020, 10:20:50 am »
Sorry Martin Dave's Right under £7 on flea bay not cheap by some other makes/kinds but I think its the best.
 I do hope your still enjoying.
           Regards Howard.
Taranis
  • Balne Moor MBC
Re: Card TID Tug
« Reply #42 on: April 01, 2020, 10:32:53 am »
Plus £3 delivery = £9.76
Amazon delivery free
ANDY
Re: Card TID Tug
« Reply #43 on: April 01, 2020, 10:49:32 am »
Beat me to it Tranis!   ok2
Plus I use Amazon 'prime', no quibble guarantee.
Taranis
  • Balne Moor MBC
Re: Card TID Tug
« Reply #44 on: April 01, 2020, 10:51:49 am »
I always check total bottom line. I'm also an Amazon prime member but that glue is not on prime and free delivery to anyone.
The Proxxon 250 Lathe is hundreds of pounds cheaper than anywhere else  O0  but I can't afford it  <:(
ANDY
mrzippy
Re: Card TID Tug
« Reply #45 on: April 01, 2020, 12:00:30 pm »
Hi Martin,
Any old PVA or Aliphatic 'white glue' kicking around that's going thick? will be similar to above,
or leave the bottle top off a while to thicken it -
white glue will allow time to position parts and none of the white staining soaking through the card, that can happen with cyno.
Finger pressure will transmit heat through card and part set white glue in moments,
or because this is more akin to aeromodelling - get the pins out !
my recent revelation - good old BluTack for positioning, this has taken over from pins, clamps and jigs etc wonderful stuff.
Re: Card TID Tug
« Reply #46 on: April 01, 2020, 12:53:10 pm »
... funnily enough, I've ordered some Neodymium magnets to help with the clamping!
mrzippy
Re: Card TID Tug
« Reply #47 on: April 01, 2020, 02:30:09 pm »
...good, outside the box thinking Batman, they would work well, small flat lead weights can also be useful !
PVA poured in a dish and left while to evaporate and thicken should work a treat depending on how thick/absorbant your card is,
its too 'wet'? straight out of the bottle.
50 years ago (pre cyno) it was the only glue available in the commercial art world for assembling mock up card packaging etc,
then along came Spraymount and changed the game !  would like a £ for every can of that I've inhailed over the years !!
I'll be joining you on the card modeling front before long, the way things are going -
had no idea of the wide range of model subjects available in card kits, stunning projects to build.
Page created in 0.15 seconds with 21 queries.
