Pages: 1 2 3 4 [5] 6 7 8   Go Down
Author Topic: Proxxon PD 250e Lathe accessories and upgrades for beginner  (Read 18301 times)
Taranis
  • Balne Moor MBC
Re: Proxxon PD 250e Lathe accessories and upgrades for beginner
« Reply #100 on: April 23, 2020, 03:17:41 pm »
I've been dreading them cancelling the order  <:(
Well they haven't  :}   Item has been despatched!  delivery 30th April
I guess they've had to order direct from Proxxon given the slow delivery. Also tracking shows DHL which would support my theory
My 4 jaw chuck has also been despatched today from a German company who had to order it in.
ANDY
Youíll only know your best effort if you donít give up.
Taranis
  • Balne Moor MBC
« Reply #101 on: April 23, 2020, 07:07:47 pm »
I now have a tracking number and Amazon have procured the Lathe from Spain. Currently at a hub in BarTHelona   {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #102 on: April 25, 2020, 11:34:17 am »
I bought a chip tray splash guard from Germany as it was far cheaper than some idiots are asking for. Unfortunately it was sub standard so I returned it as defective. The whole 3 week debacle left me £9.50 short of what I paid due to the PayPal mafia.
Anyway on the strength of my Lathe being in transit I have bought another tray from Amazon as a damaged box item but perfect condition. It just arrived by Hermes and no damage to box or anything else? anyway it's mint and at £93 a huge saving again more than mitigating my previous loss by far.
I believe the raised holes are meant for fixing it down so any fluids cannot leak through perhaps?
ANDY
Taranis
  • Balne Moor MBC
« Reply #103 on: April 25, 2020, 01:37:08 pm »
Nothing happening  :o  Still no delivery date for Lathe.
This Diamond bit just arrived from Amazon. To drill the Quartz base
Instructions
This drill bit is the dog's dooda's
Base foam fixed with spray adhesive
Awaiting delivery
P.S. Highest price observed for chip tray is a mighty £225 only a complete idiot would pay that  {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #105 on: April 25, 2020, 06:07:36 pm »
ANDY
Taranis
  • Balne Moor MBC
« Reply #106 on: April 25, 2020, 08:51:33 pm »
First modification using scraps of wood and Stixall. These Led Lamps benefit from a thick chunk of wood for stabiliy.
ANDY
Taranis
  • Balne Moor MBC
« Reply #107 on: April 28, 2020, 11:59:44 am »
Independent chuck arrived. These are far from cheap but importing from Germany was cheapest option and worked out as £148 delivered or Ä168
ANDY
Mark T
« Reply #108 on: April 28, 2020, 04:17:31 pm »
That looks well engineered  :-))   If its anything like the proxxon dividing head that I bought it should be great!
Taranis
  • Balne Moor MBC
« Reply #109 on: April 28, 2020, 04:30:31 pm »
The lathe is arriving tomorrow and as if fated the Ikea bench is coming same day
The only proxxon rubbish Iíve experienced was the chip tray I sent back, it should have been rejected or sold as C grade.
I canít find a well priced dividing head since they were on Amazon when you got yours
Iím in no rush and watching the prices  :-))
The £290 saving on the lathe has paid for many of the extras
ANDY
Taranis
  • Balne Moor MBC
« Reply #110 on: April 29, 2020, 03:32:10 pm »
Just back from shopping this morning and right out of the blue 10 a.m. The eagle landed.
I could have been out  %%
ANDY
Taranis
  • Balne Moor MBC
« Reply #111 on: April 29, 2020, 03:36:05 pm »
First impressions are I'm really glad my wife paid or I'd have to settle for a Chinese job  :((
Really feels like its worth the price
ANDY
Taranis
  • Balne Moor MBC
ANDY
Taranis
  • Balne Moor MBC
« Reply #113 on: April 29, 2020, 04:04:00 pm »
Here I need help! pleez
It's been a while and German doesn't help.
Clearly the top legend refers to the belt drive configuration. This comes pre set in the mid range, no problem
Next down is material types but I'm not clear on what its telling me? V (m/min)
Finally the bottom section?? is that a double dose of Dutch  %%
ANDY
Cornishman
« Reply #114 on: April 29, 2020, 04:51:43 pm »
    Fom the top
     Aluminium
     Brass
     Steel
     Free Cutting Steel
     m/min.  metres per minute cutting speed
Taranis
  • Balne Moor MBC
« Reply #115 on: April 29, 2020, 05:01:10 pm »
Thanks. Metres per minute means nothing to me, how is that measured on a lathe?
ANDY
Cornishman
« Reply #116 on: April 29, 2020, 05:13:23 pm »
   it would be the circumferential speed of the material passing the cutting tool.
Cornishman
« Reply #117 on: April 29, 2020, 05:17:29 pm »
   The long german word beginning sch....  translates to cutting speed.
Taranis
  • Balne Moor MBC
« Reply #118 on: April 29, 2020, 05:18:16 pm »
So it's basically just a guide to the relative difference between materials? with quite a range in each material.
There must be a formula then to calculate 10mm brass into a desirable rpm for example to fall within the m/min range
ANDY
Mark T
« Reply #119 on: April 29, 2020, 05:47:03 pm »
This is mainly for auto feed on the slide if its got it.  If not don't trouble yourself you'll know if you get it wrong trust me  {-)   Lovely lathe  :-))
frazer heslop
« Reply #120 on: April 29, 2020, 06:58:15 pm »
Most tip manufacturers have online calculators
As an example  [size=78%]https://www.sandvik.coromant.com/en-gb/knowledge/machining-formulas-definitions/pages/general-turning.aspx[/size]
They are of none or very little use for our small machines
You will know when you get it wrong usually accompanied by squealing/chattering or and swearing .
I would have though in the machines book would be some idea for speeds and D.O.C depth of cut
Good luck with the new toy
cheers
Taranis
  • Balne Moor MBC
« Reply #121 on: April 29, 2020, 07:08:51 pm »
Thank you
I just tried brass and I guess experience over time will be the way forwards. It cut very easily at wide range of low speed.
Now I realise I need a stock of shims. The indexed tools I bought seem to need 0.6mm
However the quick change tool post would negate the need.
ANDY
Taranis
  • Balne Moor MBC
« Reply #122 on: April 29, 2020, 07:17:49 pm »
Shelf is very useful
I've removed the idiot proof spring
Extra Ikea table came as promised. Loads of space now  {-)
ANDY
Mark T
« Reply #123 on: April 29, 2020, 07:32:54 pm »
Andy fixed tool holders are a pain in the preverbal's as you've just found out.  If you do need to shim take the tool down to the tail stock and level the tool with the point on the morse taper.  It makes a good start to get it central  :-))
frazer heslop
« Reply #124 on: April 29, 2020, 07:45:41 pm »
Now is the time to keep those empty biccy tins ,beer cans and so on for shim
A simple guide for setting tool height is place a 6inch rule on the job and nip it lightly with the cutting tool and look to see which way its tilting .When the tool is correctly set the rule will be vertical
Another rough A$$d way is to mark a set square by rubbing it against a center or you could make a little gauge theres loads of designs on the net
Harold Halls books are very cheap and well worth the money
Pages: 1 2 3 4 [5] 6 7 8   Go Up
