This posting should read -
New project, a simple steam drake tail, dove tail or torpedo stern launch depending which bank of the big pond you reside,
was to be tested/launched next month at Mayhem 2020 Wicksteed Park.
Sadly now in 12 weeks self isolation I'll post pictures of work in progress dents, filler, warts and all.
Loosely based on an old Midwest kit image found online, redrawn and sretched to 28 inches overall with a drake tail grafted on
to create a vintage theme, powered by a simple Saito single cylinder steam plant imported from a model shop in Poland.
My first attempt to build a hull using Lite Ply throughout -
seems to be successful allowing much easier and quicker cutting/sanding of parts, how robust it will be long term?, only time will tell.
Deck and interior ideas are in best 'Corn Flakes box' development stage to be produced in real timber.
'Nordlys' if you're reading this -
it is the hull I mentioned in your post 'Resin not hardening completely' that required baking with a hair dryer to fully set
the Easy Composites epoxy resin applied to the interior, hope to tackle the exterior later this week.
