Author Topic: 83-85mm OD tube?  (Read 1325 times)
tizdaz
  • Boom!
83-85mm OD tube?
« on: April 18, 2020, 04:38:27 pm »
Hi guys
Anyone know of anywhere that i can purchase some plastic solid (not flexible!) tube, or anything that is as light weight with the following dimensions!
Outer Diameter: 83mm to 85mm (anything within this diameter will be good!)
Length: 350mm (obviously if it only comes in longer lengths that is fine as i will just cut it!) ..on flip side if it only comes in shorter lengths i will also just buy a few & join them!
Ive been looking for a long time, only place i have found is ebay from china which is for a 500mm length but it costs £20! this is all i can find so if need be i will just buy this but it is a little on the steep side price wise just for a little plastic tubing..so any help much appreciated if anyone knows of anywhere cheaper!
Any ideas?
Or if anyone who does 3D printing could maybe print one that i can buy :) ?
Cheers!
My large-scale TID Build Website: http://www.tizdaz.co.uk/forum
Facebook:
tizdaz
  • Boom!
Re: 83-85mm OD tube?
« Reply #1 on: April 18, 2020, 05:56:30 pm »
i made a mistake on Length, its 300mm! (not 350mm as stated above!)
Facebook:
Big Ada
« Reply #2 on: April 18, 2020, 06:18:54 pm »
Tube or solid?
Tube = You could try Plumbers Rain water Pipe.
Len.
kinmel
« Reply #3 on: April 18, 2020, 06:23:28 pm »
If  a 1mm tolerance is ok, then 82mm downpipe is readily available from just about any plumbing merchant.
« Reply #4 on: April 18, 2020, 07:29:05 pm »
If 'solid', we used to buy nylon rod from RS (other suppliers out there) without going through the old company archive (used as plastic strand separator on a strand drier - R&D) I cannot give the dimensions, but I would assume the diameter was about 80mm
i.e. something like
https://uk.rs-online.com/web/p/plastic-rods/1847119/ white (this one is at the start of the list I selected so is under sized)
https://uk.rs-online.com/web/p/plastic-rods/1935323/ Black (and equal or larger diameters are more expensive)
Although not purfect it can be machined to the O/D you need, though expensive
The Old Fart
« Reply #5 on: April 29, 2020, 09:37:38 pm »
'Now I realise I need a stock of shims.'
I use old sets of feeler gauges...
Page created in 0.084 seconds with 21 queries.
