Author Topic: brushless motor couplings and prop shafts  (Read 4748 times)
Klunk
« on: April 25, 2020, 02:02:03 pm »
as above
what are peeps using.
this is for crash tenders etc using 3650 1400 kv motors.
used a standard red coupling but stripped the coupling.
im also wary about using these standard prop shafts as well. i only use the metal bearing ones, but im sure the rpm is not going to do thrm much good long term
full time penguin
DaveM
  • Why on earth do I do this?
Re: brushless motor couplings and prop shafts
« Reply #1 on: April 25, 2020, 03:26:45 pm »
Both SHG and SLEC now make those couplings with a chunk of hard rubber between the two metal parts. I've used both types with 35mm outrunners - no problems. The SHG type offers more choice of diameter and thread/plain, but the SLEC ones are a lot cheaper! https://www.slecuk.com/boat-accessories/coupling-3mm-x-4mm-flexi
DaveM
« Reply #2 on: April 25, 2020, 03:51:33 pm »
Modelboatbits also sell this type in a range of sizes. As Dave says they are probably the best for high revving brushless motors. No whirly bits to come apart!
Klunk
« Reply #3 on: April 25, 2020, 04:36:03 pm »
hi Colin. the whirly parts not only come apart, but they melt the plastic splines!
full time penguin
« Reply #4 on: April 25, 2020, 05:37:23 pm »
What about replacing the center bit with car water hose or heavy silicon tubing, silicon  Vacuum hose?
radiojoe
« Reply #5 on: April 25, 2020, 06:17:42 pm »
Hi Klunk    I'm fitting the bonded rubber ones on my Huntsman very strong and they have a quite a lot of alloy each side of the rubber bit to act as a kind of heat sink just a thought.
Joe
« Reply #6 on: April 25, 2020, 07:03:12 pm »
With those couplings they won't generate heat as there is no friction involved.
radiojoe
« Reply #7 on: April 25, 2020, 07:30:19 pm »
I was thinking about any heat that may be transferred from the motor shaft.
Joe
« Reply #8 on: April 25, 2020, 07:42:09 pm »
In which case you haven't lined it up right!  :-)
Best to use a sleeve when mounting the motor to ensure it is OK.
ChrisF
  • What's my favourite cake!
« Reply #9 on: April 25, 2020, 10:20:17 pm »
I think Joe is referring to heat generated by the motor and transferred down the motor shaft?
In theory there shouldn't be any heat produced by a Huco type coupling if it is set up correctly as there won't be any friction. And in theory the bonded rubber ones could produce heat if they aren't correctly aligned due to the flexing of the rubber.
I use the Huco type on low powered models, but use the quality Raboesch ones, and on higher powered ones also use the bonded rubber ones. All set up with solid couplings of course.
Chris
« Reply #10 on: April 25, 2020, 10:30:04 pm »
If enough heat is transmitted down the motor shaft to melt the coupling then there is something seriously wrong with the setup!
Klunk
« Reply #11 on: April 26, 2020, 05:14:39 am »
it was not heat that did mine in.it was slippage between the brass insert and plastic outer. it had worn the plastic splines. all couplings have a theorectical limit on them.
full time penguin
Taranis
  • Balne Moor MBC
« Reply #12 on: April 26, 2020, 08:17:59 am »
I fitted the solid coupling to align everything perfect before actually glueing the motor platform to the hull.
I then fitted the alternative that Joe suggests with the rubber insert. I found that this was worse than the solid coupler so swapped them back. Sometimes the rubber part loses perfect alignment or balance.
Perfect
NOT good in my case
ANDY
Taranis
  • Balne Moor MBC
« Reply #13 on: April 26, 2020, 08:46:30 am »
You could glue the brass inserts in place perhaps? A builders adhesive sealant should do the job on a new coupling of course
ANDY
« Reply #14 on: April 26, 2020, 11:36:30 am »
If you keep the coupling length short silicone tubing on the huco inserts can transmit huge torque.
Page created in 0.015 seconds with 20 queries.
