Like many members of Mayhem I've been filling my spare time with some hobby work. It's been quite an interesting exercise to see what I've had stashed in my stock of model stuff and I have to admit a fair amount had been forgotten about until rediscovered!
On the completion of the latest model, being unable to nip out to the usual sailing water, it was tested in the garden pond. Well, it floats, it's stable and can be shunted around OK is all that can be said until better times return. But, one pleasing thing was that during the design process, the models likely operating weight is estimated. In this case the expected model weight proved to be spot on at a shade over 4 pounds (approx 2 Kg).
The method used to estimate my models weight is simple, more complex methods could be used but I'm quite happy with an Engineers "Ball park" figure. This is usually enough to show if my plans are practicable or perhaps nudging into the impossible region and need modifying.
The volume of a block of water needed to float the model in is calculated by multiplying the waterline length, by the beam and draught of the model as shown in the figure. Now, unless you build your model with a hull shaped like this block, the real hull will not occupy the whole volume of this block. The block's volume needs multiplying by a suitable fraction less than one, this is termed the "Block Coefficient". If the resulting volume of the submerged part of the hull is then multiplied by the density of water then you have the mass of water the hull displaces which corresponds to the weight of the model.
It might seem a little complex but can be simplified. With the sort of models I usually built it's as follows;
Model weight (ounces) = overall length x max beam x draught (all in inches) x 3/8
For example something like a destroyer type of model, 32 x 4 x 1.25 x 0.375 = 60 ounces
The constant 3/8 (or 0.375) was found by looking at lots of my models and proved to be good enough for the combination of Block Coefficient and the density of water to give a result in ounces. Using other units for lengths and density would need a different constant.
Like I said before, but am obliged to repeat, the constant 3/8 or 0.375 works with the type of models I usually build. For other types you will probably need a different value. If building say a model based on a tug, just find the a few similar shaped hulls and use their sizes and weights to work out the appropriate constants value.
All this is not essential when designing a new model, but I'd rather have the reassurance that my plans are in the "Doable" area, maybe nudging towards the "Questionable" zone but definitely not well and truly in the "Impossible" region!
Glynn Guest
