Author Topic: Newbie Modeller - Budget Running and Control Gear  (Read 2779 times)
Boxerman66
« on: April 27, 2020, 08:45:56 pm »
Hi Folks,
I am building my first model... based on Riva Aquarama.
As this is my first go at build plus spending money, any recommends for running / control gear?
As I am not sure if the bug will bite I want to get this model floating and operating cheaply.
It’s a minefield for propulsion and control... well I think so!!
So 2 motors and 1 rudder (not sure if I want motors separately controlled or they can tandem).
R/C transmitter / receiver, ESC, batteries.
Is there any mileage in buying a full kit and using the guts by disassembly?
Are there lowish cost kits around to make life simple for me.
I’m not looking for bells and whistles just functionality. Cheers in advance.
Stan
Re: Newbie Modeller - Budget Running and Control Gear
« Reply #1 on: April 27, 2020, 09:49:48 pm »
HI Pm sent.
Stan.
« Reply #2 on: April 27, 2020, 10:30:33 pm »
Hi Folks,
If, by "full kit" you mean a ready to run model, then the answer is generally no.
An Aquamarina should be a fast boat.  Going fast is rarely cheap and successful, whatever the size.  What size are you proposing?  Size and speed wanted largely determines the parts required.
john44
« Reply #3 on: April 28, 2020, 09:52:38 am »
Hi, the riva,s are not a boat for a beginner, they are normally double planked and then veneered
Also resin coated and polished to a high standard. Very time consuming. I have built 3 versions
of the riva. Materials, running gear electrics are not cheap for this type of model.
Because their are 2 off motors esc,s if you go brushless props, etc.
If you are not sure wether you will enjoy sailing, After this lockdown is over
visit your local lake which a boat club use.
Tell them you are interested but not sure if it is for you and there will be someone who will
let you sail their boat and answer any questions you may have.
Boxerman66
« Reply #4 on: April 28, 2020, 05:59:52 pm »
Hi guys,thanks for the replies... I tend to agree with you on not a beginners model, but hey it has been started and will be finished. I’ve always admired the Aquarama hence the decision to do it.
I am enjoying the challenge and the steep learning curve during lockdown. Yes I have made mistakes and any future one will be made differently.
As it is my first, I will not be expecting perfection just experience.
The hull and sides are double skinned, deck single planked and I am, for first attempt reasonably happy...much room for improvement!!
Onward and upward eh!! Cheers
Stan
« Reply #5 on: April 28, 2020, 07:23:22 pm »
HI Boxerman66 Follow this link to my Grand Banks build. This is a typical layout  for two motors either brushed or brushless motors. Two speed controllers fitted in this installation
Stan. :-)) :-)) :-)) :-)) :-)) :-)) :-))
https://www.modelboatmayhem.co.uk/forum/index.php/topic,63493.0.html
Stan
« Reply #6 on: April 28, 2020, 08:09:04 pm »
Hi Boxermann66 this link shows a three brushed motor set up all motors running off one speed controller. Some good shots showing multi rudder set ups. The original radio was 27 MHz  but this was replaced with 2 channel 2.4 set
https://www.modelboatmayhem.co.uk/forum/index.php/topic,51992.0.html
DJW
« Reply #7 on: May 01, 2020, 07:40:19 am »
Morning Boxerman
I'm building the Aquarama too, but based on the Amati kit so it's 1/10 scale. I already had a 6 channel radio so that's being used. I'm fabricating quite a few parts where possible, sometimes to keep costs down, sometimes because I can't find correct part, sometimes because I like making the parts...   :-))
The build log is here
https://www.modelboatmayhem.co.uk/forum/index.php/topic,64276.0.html
Are you building from scratch/ plans..? What's the length..?
Would be great to see some pictures to see how far you've got.
I'm listing most of the parts and fittings that I'm using in my log if that's any help.
Best regards
David
Page created in 0.038 seconds with 21 queries.
