...been a few posts about sanding sealer recently. I don't ever remember it being a "covering" or a "coating". I mean it's fantastic for sealing things "hairy" like balsa or any raggedy edge end grain materials but never heard of it as a full "coating" until recently -when folk are perhaps rightly to say not to, because, maybe its just me but I never saw it used that way before over a big surface on a model?
...Polyester versus epoxy. Well enough out there already.
I have been using cellulose sanding sealer for more years than I care to remember as first coats ( usually three or more ) on timber/plywood models. Often slightly thinning the first coat for timber penetration. Then followed with spray or brush on primer, finally finishing off with either enamel or acrylic top coats. No adverse reaction problems yet!
The photos show my latest build, LCT-6 from 4mm ply over a glassfibre donor hull. The timber was sanded down and filled first. Then I tried Guild Materials Spray Sanding Sealer. It seemed counter intuitive to have a grain filling cellulose based product in a spray can, it wasn't an issue and it worked very well. The top coats were also from Guild, their light grey enamel aerosol, plus their brush on dark grey enamel. These products seem to be a replacement for the old Flair paints, and I thought I would give them a try. Happy so far.
The rest of the job will be a mix of brush on enamels and acrylics for detailing, plus whatever works for weathering effects.
