Progress but slowly....
I am building at approximately the rate that I can source the bits I need. The fire bricks arrived today, I can now build a mini hearth for welding the boilers together.
Here's a photo of the first two flanges, they came out better than the second two
. The first form I made was too shallow and as the flanges were rolled over they extended past the end, I screwed a piece of scrap to the back of it to complete the flange so that I could check the size. Once happy I turned a new form that was much longer and just .2mm smaller and this gave me a very good fit. I have attached a photo of the fit, it presses in easily with my fingers but do you think the solder will still flow or does there need to be a bit of clearance?
The new form is held in the soft-jaws, allows me to remove it and replace without loosing dimension. When parting off the flanges I could do all four and they were exactly the same. Tool was CBN and it cut the copper very nicely.
I am also curious what the 'black' is on the commercial boilers (Cheddar, et al), is it paint or some chemical process? Should I make little feet and solder them to the boiler or how are they mounted?
One boiler is about 4" long and the other is about 5" long, both are 3" diameter. I will run a 7/8" fire tube through the lower half with about six 5/16" cross tubes. Does this sound like a good idea? I hope to make a gas burner for it.
There has been some progress on the engines, I will make new standards for the double acting cylinders and keep these two for some simple single acting ones.
