This tiny 340mm delta, built from 3mm depron and using the Wltoys F949 board is my friend's design, based on one he saw on youtube. After I saw his flying very nicely, I decided to build one as well. I have still to test it, it is 22g with a 100mah battery from my racing mini. These lasted for 20 minutes of mini racing, it will be interesting to see how long they last with a slightly bigger motor, and probably using more throttle. My friend used 2mm depron for his, I only had 3mm. It has 1mm carbon leading edges glued on, then sellotape over . He used carbon pushrods, mine are bamboo from a roller blind. His is 19g with a 70mah cell. Pretty close. Thrust from my motor is 16.5g, he reported his as pushing 21g, maybe a better battery or maybe my motor? Mine was from a well used quadcopter, his had much less use and was a different make. If mine flies ok, I will be happy with my 16.5g thrust.
As my F949 board has a dead servo, I ordered another one from China, my friend has given me one of his boards so I can get flying, he will get my new board when it arrives. Hope to get out for some flying soon, its pretty windy when the plane weighs under an ounce.
