Tug Fanatic
I am old school, what is a proportional controller, and how does it work ?
Geoff
If you want a full explanation then send me your E-Mail address via a private message and I can send you a copy of an article.
If you simply want the basics then it's an electronic device which plugs into the receiver, exactly like a servo, and is operated via the throttle stick on the transmitter. This stick is usually spring-loaded in the centre. When you push the stick up towards the top of the Tx then the motor starts up slowly in forward mode. The motor speed is directly related to how far you move the stick i.e. it's proportional to the stick movement. At its extreme the motor runs at full speed when the stick is hard up against the stop. Reverse is the opposite - you pull the stick down towards the bottom of the Tx case.
The speed controller also has four thicker cable connections: two are to the battery positive and negative, and the other two are to the motor poles. With a brushless motor speed controller there are three motor connections. Many electronic speed controllers also have what is known as Battery Elimination Circuitry; this takes the power from the main motor battery and reduces the voltage down to power the receiver via the 3-wire lead and plug, so you can do away with a separate battery pack just for the receiver. I've attached a diagram which shows how it all fits together in a typical model.
I wouldn't recommend using an on-off switch for motor control these days, mainly for the reasons which Tug Fanatic has given.
Dave M
