Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 83202 times)
Taranis
  • Balne Moor MBC
Re: Andy's Amati Riva Aquarama build
« Reply #100 on: July 14, 2020, 08:47:37 pm »
Cheers Martin  :-))
That ok Mark ??
ANDY
Mark T
« Reply #101 on: July 14, 2020, 08:57:51 pm »
 :-)) {-)  Yea cheers mate I didn’t think you would do it - brilliant  %% {-)
Taranis
  • Balne Moor MBC
« Reply #102 on: July 15, 2020, 08:25:18 pm »
Coming home tomorrow. Glamping in a field by the sea when the weather is pants is just a waste of time. However the Boulogne Etaples got her maiden voyage  O0
I've been thinking about my rudder options and I think I've settled on a pair of size large brass stock units with 60mm sleeves and 70/75mm shafts. These have water seals too and the plan is to re model the large blade down to a suitable size and shape.
ANDY
Taranis
  • Balne Moor MBC
« Reply #103 on: July 16, 2020, 12:30:40 pm »
These were waiting for me this morning  :-))
13grams a pair
They cope with the 19,000 rpm plus of my jet drives so long as alignment is accurate.
ANDY
DJW
« Reply #104 on: July 16, 2020, 12:36:01 pm »
Haha, welcome back....  Normal service is resumed.
See you went for the helium filled ones.
Taranis
  • Balne Moor MBC
« Reply #105 on: July 16, 2020, 02:02:59 pm »
Cheers David  :-)
First job was masking the motors as they are magnetic!! to put flats on the shafts.
Comments invited regarding my shaft angle  :}
I've taken it that the shallower the better. To go steeper requires shimming the motor bed.
ANDY
SailorGreg
« Reply #106 on: July 16, 2020, 02:07:11 pm »
Surely shallow angle is good - less force depressing the bow, more force pushing you along.  Looks perfect to me  :-))
Greg
Taranis
  • Balne Moor MBC
« Reply #107 on: July 16, 2020, 02:09:47 pm »
Cheers Greg that is my line of thought also  :-))  I'm also thinking with an 8mm prop tube I'll gain nothing by fitting P brackets
ANDY
SailorGreg
« Reply #108 on: July 16, 2020, 02:53:01 pm »
My Dumas Chris Craft has a similar unsupported overhang of the prop tube at a slightly steeper angle than yours.  The kit instructions suggested gluing a triangle of wood in to support that overhang but I didn't and I've run the boat regularly for several years now without any ill effects.
Just out of interest, are the holes left by the pins in the planking any bother?  I have always shied away from doing something similar as I felt you could end up with a finish with measles.  Although I guess as there is a second planking to come, holes don't matter too much at the moment.
And hurry up - I expected you to be finished by now!   {-)
Greg
DJW
« Reply #109 on: July 16, 2020, 03:05:47 pm »
Hi Andy
My view is the shallower the shaft angle the better for the 1/10 version. They seem to dig in at the bow with a build that follows the plans. I think the steep angle lifts the stern, contributing to the bow digging in issues...
Also, the full size boat has two big V8s under the sundeck and the fuel tanks right at the stern, so my guess would be that the full size boat has most of its weight further aft than the models. Upshot is the steeper angle helps lift the stern on the full size boats.
Just my opinion.
Best regards
David.
Taranis
  • Balne Moor MBC
« Reply #110 on: July 16, 2020, 03:30:30 pm »
Thank you for the support you two  :-))
Yes Greg all the nails on the first skin can be ignored. Holes in the mahogany I feel benefit from the extra fine nails I am using. I believe Mike applies soapy water that helps the holes disappear. Amati suggest mahogany sanding dust and adhesive. I'll see when I get that far.
Some items in the instructions show the use of nails where it's simply not necessary.
Example
These parts should not be glued as per instructions as they are too long.
Black line is cutting point
Better to trim it down to length before gluing
ANDY
Taranis
  • Balne Moor MBC
« Reply #111 on: July 16, 2020, 10:00:53 pm »
Thanks to an update from Mike I can be assured that by using the very fine brass pins that wetting the wood before sanding will make the holes disappear for the most part. The nails in the kit are quite THICK, I have not even opened the packet. I bought the thinnest 0.5mm from CMB. To members that's £1.56 per 100, I re use as many as possibly but some will be so badly bent they get binned. I ordered 200
Hope that helps  :-))
ANDY
DJW
« Reply #112 on: July 17, 2020, 08:20:04 am »
Agreed about the Amati supplied pins being too thick, I found too many were also of varying length, a few blunt tips and a few with heads that didn't fit the pin pusher...  I'm also going with the finer 0.5mm versions for the mahogany layer.
I'm thinking that the 'swiss cheese' technique of boat building also allows better access to the inside of the lime layer, and this will allow use of the little rare earth magnets to keep the planks tight / flush in place of clamps.
Taranis
  • Balne Moor MBC
« Reply #113 on: July 17, 2020, 08:22:40 am »
Magnets occurred to me also  :-))  but certainly it makes it easier to coat the inside of the planking with resin.
Have we any idea of the target weight required?
ANDY
Taranis
  • Balne Moor MBC
« Reply #114 on: July 17, 2020, 07:54:34 pm »
I am making progress  O0
Amazon delivery
ANDY
Stan
« Reply #115 on: July 17, 2020, 08:54:12 pm »
HI Andy use that make of tack cloth all the time always good results.
Stan.
Taranis
  • Balne Moor MBC
« Reply #116 on: July 17, 2020, 10:04:25 pm »
Good to know Stan, as recommended by ukmike  :-))
Reached the point of making decisions regarding the bow spot lights.
I've opted to start by sanding a taper into the housings.
Position and angle is pretty much up to the builders eye.
I've left enough wood that they still need sanding back for the planks
ANDY
Taranis
  • Balne Moor MBC
« Reply #117 on: July 18, 2020, 02:24:38 pm »
Earlier I alluded to using stock brass rudders and remodelling them to suit.
These are size large and have just enough thread length to fit the model.
ANDY
Mark T
« Reply #118 on: July 18, 2020, 03:47:25 pm »
Thats a time saver  :-))   Just a thought Andy is it a little short as it looks like half of the props driven water will just pass straight underneath it?
Taranis
  • Balne Moor MBC
« Reply #119 on: July 18, 2020, 05:09:50 pm »
That's how it is on the elevation drawing Mark.
Mine is actually bigger.
ANDY
Mark T
« Reply #120 on: July 18, 2020, 05:27:31 pm »
Wow so it is!  They look so small and yet these boats handle so well but you wouldn't think it just looking at the rudders.
Taranis
  • Balne Moor MBC
« Reply #121 on: July 18, 2020, 09:45:03 pm »
Pull saw employed to accommodate batteries.
Rudder videos
ANDY
DJW
« Reply #122 on: July 18, 2020, 10:40:11 pm »
Very tidy implementation Andy. Hoping to get some time on my build this coming week too.
Taranis
  • Balne Moor MBC
« Reply #123 on: July 19, 2020, 02:33:37 pm »
Hope you do David I'm getting David's Amati Riva build withdrawal symptoms  {-)   :-))
I made a decision here as something has changed since these photographs. According to them it only takes 6 side planks to reach the bow peak. On mine it took 7 so I say they were originally 8mm planks and now 7mm.
Anyway even then the builder ended up with these silly slivers of plank on the top edge.
I decided to use some square strips I had in stock to avoid those by fitting with 2 planks to go.
This way I finish on a full plank that I can trim back
I've also ordered a Proxxon delta sander.
ANDY
Taranis
  • Balne Moor MBC
« Reply #124 on: July 19, 2020, 04:10:32 pm »
ANDY
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17   Go Up
Page created in 0.193 seconds with 21 queries.
