Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 58959 times)
chipchase
Re: Andy's Amati Riva Aquarama build
« Reply #150 on: July 22, 2020, 10:29:50 pm »
Quick tidy up and tomorrows work laid out  :-))
I might rip out the cabin mahogany walls too apart from the front panel that seals off compartment two
She's starting to take shape Andy is that your varnish in the whiskey glass   :-))
Taranis
  • Balne Moor MBC
« Reply #151 on: July 22, 2020, 10:35:26 pm »
Thank you Brian.
That is Soberano Solera Spanish Brandy, it fuels my creativity  :-)  I import it directly from Barcelona at huge saving on UK price if you can find it here in 1 litre portions  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #152 on: July 23, 2020, 06:59:59 pm »
Completed a number of tasks today.
Firstly magnetic fixing for cabin doors
Then I finished the deck skin
Magnets for sun deck
Fitted strengtheners
1st varnish on dash
ANDY
DJW
« Reply #153 on: July 23, 2020, 07:12:26 pm »
Phew...  Ready for the water by the weekend...
Looking good..!
Taranis
  • Balne Moor MBC
« Reply #154 on: July 23, 2020, 07:14:16 pm »
I was planking the bow then thought no! maybe useful for clamps yet.
Now I've just had a change of plan.... fill it in  O0
Cheers  :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #155 on: July 23, 2020, 07:31:47 pm »
ANDY
DJW
« Reply #156 on: July 23, 2020, 07:57:30 pm »
Motors in..?
Taranis
  • Balne Moor MBC
« Reply #157 on: July 23, 2020, 10:14:09 pm »
Motor bed motors mounts and couplings add 194g
ANDY
ukmike
« Reply #158 on: July 23, 2020, 11:07:17 pm »
Hi Andy.
Something for you to peruse when you aren't busy building. I think David will pick this up also from here.
Not a lot of use but quite interesting.  http://www.morosinigiovanni.com/Immagini/Prodotti/Media/CatalogueENG2020.pdf
Mike.
Taranis
  • Balne Moor MBC
« Reply #159 on: July 24, 2020, 09:42:42 am »
Thank you Mike
Today I will complete the foredeck skin then it will be sanding sanding ...... sanding.
Ready for mahogany
ANDY
ukmike
« Reply #160 on: July 24, 2020, 11:27:39 am »
Morning Andy.
Don't know if you noticed this on my Riva blog, but a good way to make sure that the sanding has removed all of the high spots, just scribble all over it with a pencil, the more scribbling the better. Then sand and sand until all the scribbling has gone, then it's done. For a final finish wet the planking with very slightly warm water with a little washing up liquid added. That raises the grain, then finish off with your finest sand paper.
This applies to the mahogany also before Varnishing.
Hope that helps.
Taranis
  • Balne Moor MBC
« Reply #161 on: July 24, 2020, 11:57:14 am »
Yes read it thanks but very appropriate to reiterate  :-))
Still waiting for my proxxon delta sander from chronos
Website says delivery may take longer but I informed them that is irrelevant if they take 5 days up to now to process the order before posting  <*<
ANDY
ukmike
« Reply #162 on: July 24, 2020, 02:06:18 pm »
Good afternoon Andy.
I know exactly what you mean about delivery.
I can't do anymore until some bits arrive, but seems always the one that you need most is the last to arrive, even if you did order it first.
I ordered some varnish a week ago and a replacement brush for the vacuum cleaner Wednesday, the brush arrived this morning but no sign of the varnish.
I'm off to the shed now and maybe tidy something !!!
Typical, but not unexpected, could be worse tho', in Italy a letter to the next door neighbour can take up to a week or more, not that it helps our cause at all.
Fustrated or what,  >>:-( >>:-( >>:-(
Mike.
Taranis
  • Balne Moor MBC
« Reply #163 on: July 24, 2020, 02:33:53 pm »
My varnish arrived very quickly from Brian must be regional differences in courier standards .
I just thought to add in case anyone was wondering?
Amati take absolutely no offence at the alterations we/I do to their kit and readily post my pictures on their facebook pages  :-))
There is also a link there back to my blog a number of times
ANDY
Taranis
  • Balne Moor MBC
« Reply #164 on: July 24, 2020, 03:46:59 pm »
Busy morning, nice walk into Leeds to the bank in the Sun but the first time I've had to wear a mask to put money in!
Anyway back to it. In case it's not obvious the foredeck needs to be 100% symmetrical for the inlays.
It's normal to plank from centre and alternate left and right but in addition as these are all under a half plank length I was sure to use the same piece for both sides each time. This guards against any planks that might be slightly different widths creating inequality.
Nearly there and I think I will have 4 planks surplus but don't tell Amati !!  {-)
ANDY
DJW
« Reply #165 on: July 24, 2020, 03:55:49 pm »
Haha...  Looks like you might have been trying to take (a lot) of money out..!!  All you need is a hoodie.
 :police:
I was in a jewellers this morning, very odd going in wearing a mask and gloves...
Nice approach re using same plank on both sides...  I like that.
Taranis
  • Balne Moor MBC
« Reply #166 on: July 24, 2020, 03:58:30 pm »
I will if long enough do exactly the same with the inlay planks  :-))  but next I have to replace the hot tub circulation pump  :((
ANDY
Taranis
  • Balne Moor MBC
Re: Andy's Amati Riva Aquarama build TA DA.....
« Reply #167 on: July 24, 2020, 04:45:42 pm »
My batteries included above could be half this size as they are overkill for ballast
I could easily get under 4KG if it proves necessary but unlikely.
ANDY
DJW
« Reply #168 on: July 24, 2020, 04:47:58 pm »
Does that say 4kg, or 40kg..?
 :D
Agreed re the Lipos, the two Turnigy graphene 3000mAh lipos I have are 425g for the pair...
Taranis
  • Balne Moor MBC
« Reply #169 on: July 24, 2020, 04:48:46 pm »
 :D
4087 grams :-))
ANDY
Taranis
  • Balne Moor MBC
ANDY
DJW
« Reply #171 on: July 24, 2020, 05:21:59 pm »
Yes, those are the ones I'm working with.  Seemed to be a good compromise of weight, capacity and dimensions.
Taranis
  • Balne Moor MBC
« Reply #172 on: July 24, 2020, 08:46:37 pm »
Wifey said she'll pay for my batteries so I'm posting it now on the record in case she forgets after maiden voyage  %%
Might be of interest also that the build as it stands has a balance point directly on the line of the motor couplings with batteries fitted.
ANDY
DJW
« Reply #173 on: July 24, 2020, 09:59:06 pm »
Maybe you should put the 5000mAh Lipos in a box marked '1/7 scale Aquarama'...
Just a thought...
 O0
Taranis
  • Balne Moor MBC
« Reply #174 on: July 24, 2020, 10:12:21 pm »
Now there is a thought  O0
I think I have the shape dialled in? However looking at many pictures of Aquaramas I see a noticeable difference in how extreme or not the curves are.
I assume this evolved over time so varies? If I haven't misunderstood this Amati is based on a 1970 model ??
Anyway it is what it is...
ANDY
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17   Go Up
Page created in 0.099 seconds with 22 queries.
