Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16]   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 17677 times)
Nordlys
Re: Andy's Amati Riva Aquarama build
« Reply #375 on: August 30, 2020, 03:51:04 pm »
Precise, clear instructions! Thank you for that Andy.
I suppose it doesn't become evident until you make the set up connections, which I haven't up to this point.
Nordlys.
Taranis
  • Balne Moor MBC
« Reply #376 on: August 30, 2020, 03:52:42 pm »
Very glad you understood because explaining isn't my strong point  {-)
DJW
« Reply #377 on: August 30, 2020, 05:13:43 pm »
Hi Andy
Good plan with the P40 I think. I've taken a similar approach but am using tx mixing to get same result. I think its going help reduce the banking seen on a lot of the 1/10 aquarama builds, we shall see.
Have a good trip.
David.
Taranis
  • Balne Moor MBC
« Reply #378 on: August 30, 2020, 06:13:37 pm »
I will and at least I'll have your progress to watch  :-)
Taranis
  • Balne Moor MBC
« Reply #379 on: September 11, 2020, 01:52:44 pm »
Counting down now  :-)  This time next week I'll be back  :}
I'm surprised that after 12 days away my finger tips are still healing from modelling abuse, ought to be like brand new for a while at least  {-)
It's too early to start buying anything yet but midweek I'm going go order an etched parts bending tool, most likely one by Trumpeter mid sized. There are quite a few to choose from but I doubt I'll ever need a big one and I'm not paying £75 plus for something made in China even if the brand claim made in USA  %%
DJW
« Reply #381 on: September 14, 2020, 07:33:08 am »
Morning Andy
Looks good, will be interested to see how it works out.
David.
Taranis
  • Balne Moor MBC
« Reply #382 on: September 14, 2020, 08:30:15 am »
Hi David
This is same brand but a different model to Stans.
It has four working faces and you rotate the one most appropriate to the front.
These do not get discounted and this is the best price I can find.
There are copies on Banggood but they look like they are cast and plated rather than cnc machined.
Stans 8” is over £80 delivered
The 5.5 is not far behind at 72.95 plus P&P 4.95
If I did battleships like Stan I may have spent more money for the longer models
DJW
« Reply #383 on: September 24, 2020, 08:50:51 am »
Morning Andy
Just posted something here as your thread is falling off the forum list...
You've been back a week... Wondering if you've lost the boat...?
David.
Taranis
  • Balne Moor MBC
« Reply #384 on: September 24, 2020, 10:49:26 am »
Good morning David.
It's a case of you've got to do what you feel like doing when you feel like doing it  O0
I was torn between groundhog day or continuing with an old flame on the arrival of these
Gives you a while to catch up  :-)
DJW
« Reply #385 on: September 24, 2020, 12:57:40 pm »
Ah, curse those old flames, but I can see the attraction...  Very nice indeed.
OK, give me til after Christmas and I might have caught up...
mikew
« Reply #386 on: September 25, 2020, 07:24:02 am »
Hi All
A question on the P40E after setting up and with every thing in neutral, if I apply just left or right rudder I find a motor will start which one depends on which way I move the rudder stick. If I apply throttle forward or reverse then apply rudder then I get the desired effect of inboard motor slowing down.
Mode is throttle left stick. Any help appreciated.
Taranis
  • Balne Moor MBC
« Reply #387 on: September 25, 2020, 07:37:40 am »
I don’t know Mike but that would be useful for parking the stern end against the dock by blipping the rudder.
A question for component shop
mikew
« Reply #388 on: September 25, 2020, 07:53:48 am »
Thanks for your answer Andy.
I did ask, but was told the code has never changed and has always been like that.
Something that I thought was just not right.
Oh well onwards
Taranis
  • Balne Moor MBC
« Reply #389 on: September 25, 2020, 08:18:34 am »
I can only think that applying rudder without throttle has little to no effect so it's perhaps programmed to apply a little throttle autonomously
mikew
« Reply #390 on: September 25, 2020, 08:22:34 am »
Will give it a try on the water when weather breaks !!
Once again Tks
colin-d
    • my hobby
« Reply #391 on: September 25, 2020, 09:10:58 am »
Which mode do your have the mixer set to..?
Sounds like mode 4... spin on the spot..
You probably require mode 1 or 2.. !
mikew
« Reply #392 on: September 25, 2020, 09:19:05 am »
Set to mode 1, but did try all modes and still same result
But thanks for reply.
mikew
« Reply #393 on: September 25, 2020, 09:24:19 am »
Any further replies please PM me.
Thank you
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16]   Go Up
