I decided to make up some wheels anyway, thinking that the extra drag might slow the plane even more, and might also stop it from pitching up when throttle is applied. It flies well right down to minimum throttle, losing height isnt easy unless the motor is off, usually turns are used to lose height. so slowing it down with wheels should work. If not, they can be for display purposes. I used the sharp edge of the sour apple drink lid, taped to its 'bottle?' (possible future torpedo?) to cut out wheels and tyres from 6mm depron, 2 layers for tyres, the outer of the tyre was cut out roughly with scalpel then turned gently against my home made sander. A quick hand sand and I am happy with them. The centres have ice cream tub plastic washers (made with a paper punch) glued each side, holes made with pin from both sides before glueing. Bit of paint and they look passable. I will glue the wheels into the tyres with uhu. Undercarriage legs are made from a large size paper clip. I have painted the tyres with pva for a bit of durability.
Wow, first test flight proves it has turned out perfect, doesnt nose over on landings, just sinks down onto tailwheel. Was just flying off road there. Rudder doesnt work well until the speed builds up a bit, it goes right slightly then straightens up, need to check wheel alignment again, could be just prop torque. Well glad I fitted them, looks much better, opens up flying possibilities a good bit, proper take offs and landings, touch and goes and it doesnt seem to notice the extra 4g at all. The drag of the wheels stops it pitching up so much when you give it throttle. Glides in nice for landing. I was a bit disappointed the rudder doesnt work well at low speeds on the ground, I was wanting to try taxi-ing round the living room. Lol. Sure that would go down well. I could get it airborne in the length of the living room. Definately a possibility, it can lift off quick. Bit tight for flying after that. Lol. Had to open the holes on my ice cream tub wheel washers until they rolled freely. 0.61 and 0.58 for big wheels and 0.1g for tailwheel. Tyres are 2 layers of black 6mm, wheels are 1 layer 6mm white. Washers uhu'd on. Will need to find more big paperclips the same, plenty strong for landing.
