Author Topic: New Build Springer  (Read 4567 times)
CliveJ
New Build Springer
« on: July 28, 2020, 07:28:03 pm »
Hi
I am about to start a Springer for a bit of fun  :-)
I am looking to conform to specs
Which motor ? geared or not ?
Prop which one ?
Thanks in advance Clive
Skrotiz
Re: New Build Springer
« Reply #1 on: August 14, 2021, 05:58:59 pm »
The specs are around if you search you should find some sites with drawings(might be around here somewhere to).
I think its max 40mm 3blade prop and 6V brushed motor if you plan on joining any competition.
I recently built mine with 12V and 540 55T crawler motor turning a 35mm 3blade prop, works great but will change my motor for a 80T because it's a little fast.
If you need help i can try to upload the hull drawing for you. It should be 457mm long and 200mm wide.
Skrotiz
« Reply #2 on: August 14, 2021, 06:01:58 pm »
https://www.ssmbc-fl.org/SSMBC-Springers.htm
There you have almost all info needed.
I have direct drive in mine but depending on motor and purpuse you could gear it down if you like
Page created in 0.039 seconds with 21 queries.
