Author Topic: Prop tube installation advice  (Read 2115 times)
Akamini
« on: August 12, 2020, 05:53:21 am »
I'm ready to fix the brass prop tube (stuffing tube?) Into a fibreglass hull (MFA spearfish). What's the best glue for this? The instructions say liquid silicone glue...I was thinking araldite (it's going to have a fast brushless setup), can anyone give advice either way?
BeeJay UK
  • Norfolk 'n Good
Re: Prop tube installation advice
« Reply #1 on: August 12, 2020, 07:22:49 am »
Epoxy has always worked for me. Araldite or otherwise. I do prefer the slow set myself but not the easiest to find, everyone seems to want rapid.
T888
« Reply #2 on: August 12, 2020, 08:10:48 am »
Aradite is fine, just make shore the brass stuffing tube is clean from grease, oil and has now finger prints on it
Regards David
SailorGreg
« Reply #3 on: August 12, 2020, 10:31:37 am »
I have used Araldite or another epoxy for all of my prop tubes (stuffing tube is, I think, an American term) and none have given me any trouble.  Give the area of the tube that will be glued a good rub down with some fine abrasive paper and keep your fingers away from it thereafter.  Wedge, tape or superglue your tube in the correct place and angle, then tape under the bottom of the hull to stop any leakage.  Apply the epoxy from inside the hull, then prop the hull so that the glued area is as level as you can make it. (Even fairly thick epoxy will ooze away from your joint over the time it takes to cure.)  Alternatively, build a little dam around the joint with wood or plastic to contain the epoxy.
Greg
canabus
« Reply #4 on: August 12, 2020, 11:59:13 am »
Hi All
Totally on the right info !!!
We added the 10mm stringers to the bottom inside of the Spearfish to mount the motor, ESC and battery on.
This stop the hull from drumming at high speed !!!
Setup is a Hobbyking 3648-1450kv brushless motor, car ESC 120Amp, Nano tech 15.2 Volt 4S 5000mah 90C Lipo battery with a 2 blade 38mm CNC prop(pitch 1.4).
Speed, GPS at 40KPH !!!!
Canabus
Akamini
« Reply #5 on: August 12, 2020, 01:18:53 pm »
Thanks for all the info - nice tip to tape under the hull to stop the glue running out would never have thought of that!
How much runtime do you get with that setup canabus?
SailorGreg
« Reply #6 on: August 12, 2020, 01:28:01 pm »
And make sure it's electrician's PVC tape, not paper masking tape or anything else - masking tape won't peel off the cured epoxy.
canabus
« Reply #7 on: August 12, 2020, 01:59:32 pm »
Hi Akamini
Depends on the speed runs !!!
But with cruise runs and half speed on the turns a good 1/2 hour !!!
We have not push the battery to the limits as it upsets the other boat uses with high speed runs time after time!!!
But check out you plan speed run without running into other boats is a must!!!
Canabus
DaveM
  • Why on earth do I do this?
« Reply #8 on: August 12, 2020, 03:05:14 pm »
Harry's favourite party-piece with the Spearfish is a full-speed slalom run between the exclamation marks in his posts!!!   :kiss:
Dave M
Page created in 0.014 seconds with 17 queries.
