I'll see about getting some pics of all 3 lined up together.
Took me a while to figure out what was going on with the vibration. The Huntsman was really quiet at very low speed, and also when flat out. Between the two extremes, it sounded like the motor or something was trying to shake itself apart - like a playing card rubbing on bicycle spokes, but very fast.
I tried swapping the motor, motor mount and coupling.
I also swapped the ESC, incase it was a problem with one phase (brushless).
Eventually I pulled the shaft out, and rolled it on a sheet of glass (an old shelf from a cabinet), and the shaft was very slightly bowed. Only about half a millimetre, so barely noticeable. Enough to set up vibrations because it was out of balance, but not enough to physically rub in the tube.
From now on I'll be checking shafts and tubes before I use them
