Thanks Ian, I do like making gubbins
Today started making the stays/shrouds etc. and stepped the mast then rigged the sails that I prepared between varnish coats and presto it's finished.
With the aid of a 15" fan for the "Wind" I tested the sail control, very pleased how it worked except this was my first venture into sail winches and soon realized I bought the wrong winch this one has 4 turns and is way too much for what is needed, I only need half the stick movement for full sail control, I could leave it but if I used too much stick letting the sails out the extra cord is prone to tangle, so I have a 2 turn winch on order that has the same shrouded drum so I can use the same drum on the new servo, Once this is done I'll wait for a day with light winds for her first sail.
On another note the Piercing saw I bought to cut the brass for the fittings has proved to be an excellent tool I was pleased when it came with 144 blades in 6 grades as I thought I'd probably use half of them, as it turned out I'm still on the first blade, it cut out all the fittings and the glazing for the little windows, a tenner well spent.
Joe
