Indeed. Got a bit carried away trying to source something in metal when a styrene frame painted would be simpler for me!
Hello Stuw
I'm afraid my frames are 1.5mm thick aluminium alloy, but it's pretty easy to shape.
Mine is the 33 inch long AeroKits Swordsman. I bought the kit in about 1970 and it cost £5.95.
The plan that came with the kit did not show the rear cabin windows, so I scaled them off pictures of real Swordsman.
Here are the drawings of what I made, and the fixing position relative to the corner of the transom. The decorative arrow (not shown) is central on the windows.
The frames are held on with M2 domed head, hex, stainless steel screws. Once you have screwed them on you can cut out the wood using them as template. The glazings are just rectangles of polycarbonate fitted to the inside of the cabin.
I used a filing button 16mm dia, 4mm small dia to make the curved ends neat.
As I mentioned, I may put a light in the cabin. I think Bournville Model Boat club has an evening regatta, where the boats are illuminated.
Kind regards - Fuse Wire
