Instructions received and read - thanks Colin.
Both ESCs have had the red loop wire cut, so BEC disabled.
Reading the instructions, it says that the BEC can only support one ESC, one receiver and 2 servos. I guess this is why the builder has cut both loops, and used a separate receiver pack.
I'm wondering if I should reconnect one of the red loop wires, and use the ESC's BEC circuit? Will that work with 2 ESCs in the boat? It's what I'd do if I was using modern brushless ESCs - BEC power from one ESC, cut on the other one. Just a bit concerned that the instructions say that the BEC will only power one ESC.
I'll stick with 2s LiPos.
I'll set the boat up on my Tx to use 2 separate channels for the ESCs, mix for forwards and reverse, and add a bit of "outside" motor to the rudder - works well on my twin-motored Riva
