Author Topic: OceanWorks Z drives or Schottels  (Read 13294 times)
Taranis
  • Balne Moor MBC
Re: OceanWorks Z drives or Schottels
« Reply #25 on: November 13, 2020, 01:20:49 pm »
I took a propeller off this morning and can confirm mine measure 84mm
ANDY
16-21
« Reply #26 on: November 13, 2020, 02:24:04 pm »
84mm
I guess they need to update the website.
I assume your nozzles are 100/90?
Taranis
  • Balne Moor MBC
« Reply #27 on: November 13, 2020, 03:40:45 pm »
I dont know what that means but $180 each EDIT yes I guess so
Looks like he made changes since I spoke last night
https://www.oceanworkscale.com/product/z-peller-azimuth-thruster-z-drive-propulsion-combo-set-100mm-reinforce-nylon/
Main Gear: 60T , Material : POM
Motor Gear: 20T, Material: Steel
Ratio: 3:1
ANDY
16-21
« Reply #28 on: November 13, 2020, 03:46:41 pm »
I take it the outer diameter is 100mm front and 90mm rear or are these dimensions slightly more than stated,
Just going by the fact your prop is 84mm and not 80mm as it mentions.
Looks to be a solid product.
likeomg
« Reply #29 on: November 13, 2020, 07:33:54 pm »
How do you control a schottle / pod drive on a model? It's one thing ive always been curious about
At work when manoeuvring it's done with these leavers, - haven't seen anything like it for a RC before
Do most not use the schottle / pod in 360? these are our controls for 3 20MW pods
Taranis
  • Balne Moor MBC
« Reply #30 on: November 13, 2020, 07:39:57 pm »
I am steering towards 360 (pun intended)  {-)
I want to keep it simple (without spending a mint) and control is not about speed but accuracy IMHO
I will use two rotary knobs to control and indicate the position of each kort and port starboard throttles split on left right friction sticks
Only testing in the water will determine what I might change.   AND lots of practice.
From a lot of watching it seems LESS is more, see what momentum does before over reacting.
EDIT
I guess the most important thing is the direction of the thrust, no point applying any amount in the wrong direction. {-)
I dare say in time with OPENTX I can have multiple settings and flick a switch for basic sailing controls with no tow OR simply put tank steering OFF
ANDY
ray123
  • shuswap tugboat
« Reply #31 on: November 13, 2020, 08:50:40 pm »
   the canadian guys have made these R/C controls  for ASD https://www.youtube.com/watch?v=Uzg4mAWPolg&list=FLIdETMPJk9BwEnYAmIcwR4A&index=21
Taranis
  • Balne Moor MBC
« Reply #32 on: November 13, 2020, 10:00:05 pm »
That’s interesting Ray but I would say from experience that throwing a boat around sideways and spinning in open water is a far cry from the control required on a tow with obstacles everywhere
They make it look easy but I’d like to see them apply it to more than showing off  %%
ANDY
likeomg
« Reply #33 on: November 13, 2020, 10:10:41 pm »
that transmitter is a work of art, (pod leaver one) really impressive.
ray123
  • shuswap tugboat
« Reply #34 on: November 14, 2020, 04:41:56 pm »
  hi andy  i know theres a lot of show boating in the video  but they do use these controls for  model towing competitions   in this photo  this is a training tug     future tug captains  train on these models as part of  there  coarse / training!  the tug is a  true scale tug  'bollard pull and  H.P'  the model is approx 6ft loa  and the ASD  units are 6inch dia  the hadsets are custom made and use the  sticks for control!   the ship model is 47ft loa  :o
chipchase
« Reply #35 on: September 20, 2021, 09:43:10 pm »
After reading Andy's post about these Z-drives I decided to order a couple for my new build, the price and the quality is very good.
Taranis
  • Balne Moor MBC
« Reply #36 on: September 21, 2021, 08:55:25 am »
Nice blades  O0  are they aluminium alloy?
ANDY
chipchase
« Reply #37 on: September 21, 2021, 08:48:32 pm »
Im not sure Andy, but really good quality, after working out cost of materials  to make the drives it was a none starter to be honest, the ones I bought are 90mm Schottels, I was that impressed with them I placed an order for the 120mm Schottels for my new build.
Taranis
  • Balne Moor MBC
« Reply #38 on: September 21, 2021, 08:52:10 pm »
Nice I’m happy for you and for Victor, they work hard at OceanWorks with continual improvements  O0
I can’t help but notice that the leading edge of the new props appear to be very sharply profiled.
ANDY
Navy2000
« Reply #39 on: September 23, 2021, 12:15:11 am »
I found this link to a company that makes the rotation units and boards for your radios.
IMTH Innovative Modelltechnik Hamburg - Home
These by what it looks like can give us a full 360 degree rotation.
Duane
Taranis
  • Balne Moor MBC
« Reply #40 on: September 23, 2021, 08:51:58 am »
There seems to be an obsession with 360 degrees, has any one tried using it in practice on a model? I find 180 is more than adequate and its already very easy to lose track of what is where and how much power in what direction  %%  I would suggest not to waste money on overcomplicating what works fine and just spend time using it to the point it becomes intuitive. These drives at this size are extremely powerful and I have output limited to 25% but for becoming familiar with it a lower output would be easier.
Please don’t take this as directed at you Duane it is just a general observation.
Of course full size vessels have very big heads up displays of what is going on
ANDY
marco
« Reply #41 on: September 23, 2021, 10:01:06 am »
Hello taranis ,
       On my PENFRET I have 360°.
marco
Stumps
« Reply #42 on: September 23, 2021, 10:54:43 am »
Hi Marco,
Sorry this is of subject, but I have to ask... How's the Penfret build going?
regards
Ant
hama
« Reply #43 on: September 23, 2021, 11:59:51 am »
Perhaps we are deviating from subject here, but I'm with Andy/Taranis regarding 360degr rotation or not. If you really like to replicate the real thing, then go for it, but it ain't that necessary.
I don't have a podded model, but I am captain on a 40m ASD passenger vessel, and spend my days manoeuvring to and from jettys that we go nose on to. Very much like a tugboat pushing a vessel. The only times I turn a pod inwards is when turning on the spot or when steering at slow speed and you need that extra force. All manoeuvres can be done by steering the pod 180degr outward, braking, crabbing, steering. You can get unwanted effects when turning a pod inwards and the prop wash hits the hull or fin.
If I could afford it, I'd definitely buy the German system that replicate the real thing, but you could achieve almost the same thing with a much less complicated solution. If I ever build a podded model I'll try to use my Robbe F14 with two sets of twin sticks and 180degr serves.
All the best!
Hama
https://youtu.be/vHF21Ozbrd8
Akira
« Reply #44 on: October 24, 2021, 12:51:58 pm »
Taranis, You might care to take a gander at these servos.  https://www.gobilda.com/2000-series-dual-mode-servo-25-2-torque/They provide 180 degree rotation out of the box and 300 degrees with a servo expander. I have used them for animation on my models and am very happy with them. They do make a speed version, but it is does not have enough torque for your needs. They might. Check the specs.Jonathan
toesupwa
  • USA'd ex Brit
« Reply #45 on: January 26, 2022, 08:52:08 pm »
Wow..
I've just discovered these drives from Oceanworks.. Very, very nice!..
They look much stronger and better construction than the Graupner  >>:-( >>:-( >>:-( >>:-( drives..
I did something similar with the drives I built for my MHT (Modern Harbour Tug).. much more robust construction!..https://www.rcgroups.com/forums/showthread.php?1108150-A-Modern-Harbor-Tug
Rather than going with the complications of going the full 360 degrees with my drives, I went with 180 degrees and forwards / reverse, though the Mk 11 drives might be gear driven from the servo..
Taranis
  • Balne Moor MBC
« Reply #46 on: January 26, 2022, 09:29:15 pm »
Nice work  :-))
I fully recommend OceanWorks  O0
Sailing with one hand and phone in the other
https://photos.smugmug.com/photos/i-F6MVhBN/0/1920/i-F6MVhBN-1920.mp4
34kg
My favourite
ANDY
RST
« Reply #47 on: January 27, 2022, 12:22:42 am »
FAO Admin:  Nominate 1st choice next photo of the month.
(I don't know where the pics of the azi drives went in my reply)
Wow..
Page created in 0.035 seconds with 21 queries.
