I would say use the biggest that will fit and not Raboesch.I chose these most recently for a bigger build. Fit your own choice of motor http://www.hobby-lobby-modellbau.com/onlineshop/index.php/cat/c568_Brass-PVC-Tube.html
I don't think they are built well enough. My experience is they leak when the plastic splits around the motor mounting screws. The gears are plastic on the propeller version. The motor is 7.2 volts brushed which needs considering if you are using a different voltage. Lacking in power and my motor developed a dead spot so if it stops it won't run again without turning it manually first.Don't let me put you off
Hi Fred when I spoke with Ann she told me about Brian she did say it will be about 4 weeks delay on the kit When i ordered the full kit
Picked up my kit today got it home quick look at plan prop shaft end plan shows casting YB01 to support prop shaft overhang had a good look in the casting bag put I can not find any think that looks like support can anyone help ?me photos would be a big help running the big 6mm shaft Decided to go with the kit motor other one is to large for the hull
Taking a drive over in the morning to pick up my kit can’t wait to finally have it in my hands Got a couple on these going to fit one into new buildhttps://www.ebay.co.uk/itm/Electric-Scooter-Motor-12-Volt-DC-150-Watt-12v-Brushed-ZY6812-16T-Belt-Drive/164336973228?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2648
