Author Topic: Stick pins  (Read 1711 times)
Mike M
Stick pins
« on: September 26, 2020, 04:15:35 pm »
Ok I have searched hi and lo for a particular stick pin I can use in construction .It's the ones with a red or blue plastic top.The ones used in the Fairmount Alpine build log. I use T pins which are a little hard on the fingers.Can you provide a link? :-))
Cheers Mike
unbuiltnautilus
Re: Stick pins
« Reply #1 on: September 26, 2020, 07:31:36 pm »
https://www.sussex-model-centre.co.uk/steel-pins-50-pcs
Not sure about shipping to Canada, but you have a brand now and may be able to sort locally.. sort of!
Mike M
Re: Stick pins
« Reply #2 on: September 26, 2020, 07:49:22 pm »
Thank you
RST
Re: Stick pins
« Reply #3 on: September 26, 2020, 08:36:58 pm »
Interesting to see this. "Stick pins" are kind of what I've used to put rockwool insulation panels on to a surface like HVAC ducts.
I haven't seen those pins from sussex model centre before. Are they better than the usual glass bead head pins available from usual sources (the top beads always pull off)?
unbuiltnautilus
Re: Stick pins
« Reply #4 on: September 26, 2020, 08:53:47 pm »
Have not used them myself, just sell them! But they seem pretty well put together, and at the price they should be a damn sight better %)
Mike M
Re: Stick pins
« Reply #5 on: September 26, 2020, 09:07:16 pm »
Thanks everyone found them on Amazon.co delivery to Canada
Mike M
Re: Stick pins
« Reply #6 on: September 26, 2020, 10:16:36 pm »
Thank you  The wide world of Google algorithms seems the key search word is "steel" hobby pins not "Hobby stick pins"  LOL  {-)
RST
Re: Stick pins
« Reply #7 on: September 26, 2020, 11:14:07 pm »
"almost inextricably linked" ....head to the shaft. Is it or isn't it LoL. I might buy a pack to try. Usual glass bead pins the head just pulls off but they're so cheap they are consumable, I find "T" pins a bit thick, tends just to split wood rather than stick in place. Thanks for the link.
Taranis
  • Balne Moor MBC
ANDY
Mike M
roycv
Re: Stick pins
« Reply #10 on: September 27, 2020, 09:33:52 am »
Hi are we talking about the pins about 3cms long with a plastic knob on?  If so these are available from dressmakers items or Haberdashery as it was once known.
They come on a circular card.  There are quite a few items they use which are useful.
Roy
Mike M
Re: Stick pins
« Reply #12 on: September 27, 2020, 03:54:27 pm »
Taranis
  • Balne Moor MBC
Re: Stick pins
« Reply #13 on: September 27, 2020, 04:04:13 pm »
Excellent build logs Great work   :-))
Thank you Mike
Not enough room to link to them all  %%
ANDY
