David!
Was going to do one once a bit more progress made but here we go. I should have called the thread something else as there are 3 builds going on!
The downside is that less progress is made rather than doing them one at a time but the upside is that I will have multiple boats to play with, I mean run, namely 5!
Right. I'm working on the Huntress and there was a step backwards. I was never really happy with my first attempt at planking the deck, which was harder than the other two as more bending was required, and having bought the additional ply and planks I set to and did it. It's not perfect, but better (good job I'm not building a Riva!) and will be fine with some strategically placed deck furniture! Once it was glued in place I added the mahogany toe rails and upstand for the superstructure.
I've also made the battery box and made a start on sorting out the steering for the stern-drive. I'm using nylon snakes in a push/pull configuration and they will be longer than shown as the pivot and servo will go in the cabin.
I need to do a bath test to more accurately position the battery before doing more on the steering and whilst I could do this without the superstructure it's better to do it with it and so I've made a start on that. Parts have been drawn up and cut out of birch ply ready for assembly tomorrow.
Chris
