Hi Ian
The flour mill had 6 floors with each floor having about 30 flour grinding machines per floor and all were leather belt driven and each floor connected to a rope race that was driven by a huge 3 - cylinder steam engine.
The drive belts to the milling machines were jointed with Alligator metal jointing clips, still available on the market, they had teeth that the belt was cut and inserted between the teeth of one of the clips and hammered closed and the other into the matching clip that had a series of holes , just like a door hinge that allowed a slip pin to go thro' to join up the belts allowing the belt to flex as it drove the machines and as you have said produced a clicking noise as it passed over the pulleys.
All of the drive pulleys in full size were very much larger than the small pulley on Jerry's dynamo which I feel the bell will continually fall off.
You may notice that Mamod and other small steam models use a grooved pully and a spring drive belt that when cut to size one end screws into the other.
Jerry.
Once you have scarfed both ends of the belt glued before sewing, what type of glue stays bendable after sewing ?
The only adhesive that I know of is the rubber solution to mend punctures on bike inner tubes, which would allow the belt to go around such a small pulley, but then the stitching will not allow the joint to bend around the small pulley
Last question can you get the burner into the fire tube as the dynamo looks very close to the boiler.
Great job Jerry, the blue looks great.
George.
