Author Topic: Futaba 6 EXAP 40Meg  (Read 3416 times)
old_gunner
Futaba 6 EXAP 40Meg
« on: October 24, 2020, 07:20:29 pm »
Having some problems my wife chum and small grandchild paid a visit I was trimming a sub in the test tank small child was left unattended and seems to have "played" with thee transmitter which is "programmable" I can now only have two servos working and have tried reprogramming but with little effect, so I am obviously doing something wrong other than producing the longest sentence in the English language. Any ideas as the radio is liable to end up flying.
On second thoughts King Herod was not all bad you know.
Old Gunners never die, they just drop shorter.
C-3PO
Re: Futaba 6 EXAP 40Meg
« Reply #1 on: October 24, 2020, 08:03:29 pm »
Maybe worth trying a Factory Reset (RCST  Data reset function)  - see page 10 of the manual and then starting again
http://manuals.hobbico.com/fut/6exas-manual.pdf
C-3PO _._
old_gunner
« Reply #2 on: October 24, 2020, 10:33:02 pm »
C-3PO _._
Optimistically tried that still can only get the motor and the balance tank to work the rudder, planes and torpedo's still will not work, so I am not sure what the little fellow did, but he did it well.
C-3PO
« Reply #3 on: October 24, 2020, 11:03:02 pm »
Worth checking polarity of servo leads/reseating plugs on RX for the malfunctioning servos if you haven't done so already
Are you able to plug another servo into offending channels to confirm that there is an transmitter to receiver issue?
C-3PO _._
Ken G121
« Reply #4 on: October 25, 2020, 06:55:55 am »
If it is just the handset that has been touched has he changed the mode the transmitter is working in, presume you are in 2, perhaps it is now in 1,3 or 4.
I don’t know if this transmitter is also switchable between acro (aircraft) and heli mode, if so perhaps it is in helicopter mode.
Just a thought as either of these will affect stock operations.
old_gunner
« Reply #5 on: October 25, 2020, 02:08:21 pm »
Thank you for your responses, I have solved the problem by the expedient of changing the radio to a Graupner set that I had in the workshop, the Futaba will be appearing in eBay in the near future.
Page created in 0.013 seconds with 20 queries.
